How to sum up a volScalarField
Like Tree5Likes
  • 4 Post By Lieven
  • 1 Post By lin
Old   March 25, 2013, 02:39
Default How to sum up a volScalarField
Martin
RugbyGandalf is on a distinguished road
Dear Foamers,
i build a small postprocessing program, which calculates the volume of each cell and multiplies it by the a concentration of this cell. (It is a case, where I simulate the drug-transport through a coronary artery).
So I know about the mass of drug in each cell, but i would like to sum all values up, so that I get the overall value...
Does anyone have a clue, how to do this?
Thank you very much
Regards,
Martin
RugbyGandalf is offline   Reply With Quote
Old   March 25, 2013, 02:53
Lieven
Lieven will become famous soon enough
You can simply use
scalar sum = gSum(C);
where C is the mass scalarField.
Cheers,
Lieven
ayhan515, Luttappy, wht and 1 others like this.
Lieven is offline   Reply With Quote
Old   March 25, 2013, 04:05
Martin
Dear Lieven,
thank you very much for your answer.
Unfortunately wmake gives out the following errors:
wirkstoffgehalt.C: In function ‘int main(int, char**)’:
wirkstoffgehalt.C:158: error: ‘sum’ cannot be used as a function
wirkstoffgehalt.C:141: warning: unused variable ‘Gesamtwirkstoffgehalt’
make: *** [Make/linux64GccDPOpt/wirkstoffgehalt.o] Fehler 1
I added this line at the end of my program.C - Code, which now looks as follows:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 1991-2010 OpenCFD Ltd.
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
Description
    Write the three components of the cell centres as volScalarFields so
    they can be used in postprocessing in thresholding.
#include "argList.H"
#include "timeSelector.H"
#include "Time.H"
#include "fvMesh.H"
#include "vectorIOField.H"
#include "volFields.H"
#include "fvCFD.H"
using namespace Foam;
// Main program:
int main(int argc, char *argv[])
    timeSelector::addOptions();
#   include "setRootCase.H"
#   include "createTime.H"
    instantList timeDirs = timeSelector::select0(runTime, args);
#   include "createMesh.H"
    forAll(timeDirs, timeI)
        runTime.setTime(timeDirs[timeI], timeI);
        Info<< "Time = " << runTime.timeName() << endl;
        // Check for new mesh
        mesh.readUpdate();
    volScalarField C
        IOobject
            "C",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
    volScalarField cv
            IOobject
                    "cellVolumes",
                    runTime.timeName(),
                    mesh,
                    IOobject::NO_READ,
            mesh,
            dimensionedScalar("zero",dimVolume,0.0)
    volScalarField wirkstoffgehalt
            IOobject
                    "Wirkstoffgehalt",
                    runTime.timeName(),
                    mesh,
                    IOobject::NO_READ,
            mesh,
            dimensionedScalar("zero",dimMass,0.0)
    cv.internalField() = mesh.V();
    Info<< "Schreibe den Wert " << cv.name() << " in "
    wirkstoffgehalt.internalField() = mesh.V()*C.internalField();
         Info<< "Schreibe den Wirkstoffgehalt je Zelle in kg " << cv.name() << " in "
         cv.write();
     wirkstoffgehalt.write();
    IOdictionary transportProperties
        IOobject
            "transportProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
scalar sum = sum(wirkstoffgehalt);
    Info<< "Gesamtwirkstoffgehalt in kg beträgt " << sum << " in "
    Info<< "\nEnd" << endl;
    return 0;
Could you tell me, what is wrong?
Regards,
Martin
Old   March 25, 2013, 04:24
Lieven
Ok, but you should copy the code a bit more carefully (it is gSum and not simply sum) and it is also bit tricky what you try to do in your code.
You try to create a variable with the same name as the function you are calling. I'm certainly not an C++ experiment but I can imagine that could cause problems...
Cheers,
L
Old   March 25, 2013, 11:20
Martin
Hey Lieven,
I tried another way. The program from above gives out a volScalarField (let's call it "Values")
with another program, I read in Values, and tried your "gsum" lines again, but it did nor work.
# gsum is not defined in this scope
Is a header missing?
Regards,
Martin
   \\    /   O peration     |
     \\/     M anipulation  |
License
    for more details.
Description
#include "Time.H"
#include "fvMesh.H"
#include "fvCFD.H"
// Main program:
        mesh.readUpdate();
    volScalarField Wirkstoffgehalt
        IOobject
            "Wirkstoffgehalt",
            runTime.timeName(),
            mesh,
            IOobject::NO_WRITE
        mesh
scalar sum = gsum(Wirkstoffgehalt);
    Info<< "Schreibe den Wert " << sum << " in "
    return 0;
Old   March 25, 2013, 20:04
lin
Hua Zen
lin is on a distinguished road
gSum!=gsum
ZhangPikai likes this.
lin is offline   Reply With Quote
Old   March 26, 2013, 10:40
Martin
Dear Leaven and Lin,
thank you very much for your help!
It was a spelling problem of mine.
Now it works fine
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
