In which coordinates system is expressed velocity |
April 12, 2013, 04:39 |
Malik
Hi FOAMers !
I am currently working on a cylinder and trying to optimize the mesh in the domain that contains the cylinder. I would like to minimize the error due to "mesh alignment". For that, I need to have the velocity on each cell and the coordinates of the center of each cell. I made my mesh with the blockMesh utility. In the file U in each temporal folder, I can see that I have the velocity vector expressed in a coordinates system. My first question is : in which coordinate system is it expressed ? : Is it the local coordinate system of the cell ? Or every cell of each block defined in blockmesh dict has the same coordinate system ? This is a problem for me since I have some edges which are curved. Then the coordinate system of each cell with rotate from the reference defined for a block in blockMeshDict. I can give you more details if you need it |
April 12, 2013, 12:19 |
Marco A. Turcios
Rep Power: 28 |
Velocity is always expressed in the global coordinates system.
April 18, 2013, 06:00 |
Malik
Thanks a lot !
Capture x,y,z velocity at points with coordinates | startup0820 | Fluent UDF and Scheme Programming | 1 | October 18, 2012 05:35 |
Problem with time average tangential velocity in swirl flow. | lakhi | FLUENT | 5 | July 18, 2012 16:28 |
velocity components in cylindrical coordinates | iperten | CFX | 2 | March 31, 2009 08:22 |
High velocity grinding and classification system | Sri | FLUENT | 3 | July 30, 2008 10:35 |
Need ideas-fuel delivery system | Jan | Fidelity CFD | 0 | October 9, 2006 04:30 |
