April 19, 2013, 11:24 |
water velocities (point data) are all zero
Rep Power: 13 |
Hi there,
I ran a case using interFoam. The mesh is 2D (only one cell in the z direction). Y-axis is 4 m high, 0-2m is water and 2-4 m is air. The free surface (using alpha1) looks good in paraview. But when I choose U-magnitude (point data) for animation, only the inlet patch and the top of air have non-zero velocities. When using U-magnitude (cell data), the water velocities are non-zero and look normal. However, I need to extract the water velocity at sampling points or over a line to do some comparison. I cannot save the cell data via 'plot over line', only point data are saved, ie., water velocites are all zero. It is really strange to me. I am thinking maybe there is something wrong with the settings in paraview as the output U files are of non-zero values. Could someone shed some light on this please? Thanks a lot in advance. Sophie |
April 20, 2013, 03:50 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Sophie,
Maybe you could use the OpenFoam utility "sample" instead. This allows you to sample along a given line. You can find more information and an example of the needed dictionary here: OpenFOAM/OpenFOAM-2.2.0/applications/utilities/postProcessing/sampling/sample Kind regards Niels |
April 20, 2013, 06:08 |
Rep Power: 13 |
Hi Niels,
Many thanks for your guidance! I'll try it. Best wishes, Sophie |
cell data, paraview 3.12, velocity magnitude |
How to set nonuniform T, U fields from point data | MisterX | OpenFOAM Running, Solving & CFD | 0 | November 28, 2012 08:38 |
[ANSYS Meshing] Importing Cylinders by Point Data Input with Radii | EphemeralMemory | ANSYS Meshing & Geometry | 2 | May 31, 2012 13:34 |
matching variable data with grid point data | anfho | OpenFOAM Programming & Development | 0 | May 6, 2011 15:28 |
How to put melting point data of inert particle in DPM model of Fluent | subhankar_bhandari | FLUENT | 0 | July 28, 2010 07:40 |
how to create the formatted point data for icemcfd | charles | CFX | 3 | February 28, 2006 20:01 |
