Wall component calculation using foamCalc vs Solver |
February 12, 2014, 08:10 |
Bernhard
Rep Power: 21 |
Recently, I have been using the components utility of foamCalc on a vector field (which itself is a gradient of a scalar). I am only interested in one of the components of this vector (or gradient) field. I calculate this component using two methods
1. Directly in the solver (i.e. by writing field.component(0)) 2. Using foamCalc components field. Which, essentially, should do the same thing, but read the grad/vector-field from disk. The cell values are identical for both approaches, however, looking at the value of the component at a patch, then both approach give me a different result. The component value returned by the solver is the correct one, as it matches the analytical solution for a test case. The value obtained by calculating the components after reading the vector-field from disk are different. In the latter case, foamCalc seems to take into account that the (default?) zero-gradient condition, and thus returns me the cell value. This is expected behavior, and probably correct based on the input vector-field read from disk. However, it should not make a difference whether or not the field is re-read or not (in my understanding). Thus, is there information not written, when writing the gradient field? I've attached a case and solver (modified laplacianFoam solver), with which the issue can be easily reproduced (for 2.1.0 and 2.2.0 at least). The tarball contains a "Allrun" script, which compiles, run and compares automatically. Am I overlooking something? How can I get the foamCalc-route provide me with the correct solution? What information is lost when writing just the gradient-field? Last edited by Bernhard; February 12, 2014 at 08:29. Reason: Clarifications |
February 13, 2014, 13:26 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Bernhard,
I just gave your question a quick look. The issue is due to the file Code:
OpenFOAM/OpenFOAM-2.2.0/src/postProcessing/foamCalcFunctions/field/components/writeComponentFields.C Code:
OpenFOAM/OpenFOAM-2.2.0/src/postProcessing/foamCalcFunctions/field/components/components.C Code:
template <class Type> void Foam::calcTypes::components::writeComponentFields ( const IOobject& header, const fvMesh& mesh, bool& processed ) { typedef GeometricField<Type, fvPatchField, volMesh> fieldType; if (header.headerClassName() == fieldType::typeName) { Info<< " Reading " << header.name() << endl; fieldType field(header, mesh); for (direction i=0; i<Type::nComponents; i++) { Info<< " Calculating " << header.name() << Type::componentNames[i] << endl; volScalarField componentField ( IOobject ( header.name() + word(Type::componentNames[i]), mesh.time().timeName(), mesh, IOobject::NO_READ ), field.component(i) ); componentField.write(); } processed = true; } } Essentially, the solution of your problem will be to rewrite this particular function, such that the boundary types are included. This will subsequently require a loop, where the boundary fields are populated with the correct values. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
February 14, 2014, 04:45 |
Bernhard
Rep Power: 21 |
I see the point you make. However, then I don't understand how the write.H in the solver I attached does transfer the boundary condition. This is not explicitly done, and the written "grad(T)"-file has already zeroGradient boundary conditions, so is there anything left to transfer here? Or should grad(T) be written differently? I don't see a difference between the write.H file and the foamCalc components functions. (except for AUTO_WRITE versus component.write(), but I checked, this is not causing the difference))
February 14, 2014, 05:16 |
Rep Power: 37 |
Hi Bernhard,
Oh, I see your point. I will try to get some time during the weekend for a closer investigation. Kind regards, Niels
February 15, 2014, 13:19 |
Rep Power: 37 |
Hi Bernhard,
I have had a bit of fun, have been quite confused and now I think I have a waterproof explanation: First of all: Forget my entire post above, because it is not related to that! Explanation: The only file, which we have to consider is: Code:
OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/finiteVolume/gradSchemes/gaussGrad/gaussGrad.C Code:
template<class Type> Foam::tmp < Foam::GeometricField < typename Foam::outerProduct<Foam::vector, Type>::type, Foam::fvPatchField, Foam::volMesh > > Foam::fv::gaussGrad<Type>::calcGrad ( const GeometricField<Type, fvPatchField, volMesh>& vsf, const word& name ) const { typedef typename outerProduct<vector, Type>::type GradType; // STEP 1: tmp<GeometricField<GradType, fvPatchField, volMesh> > tgGrad ( gradf(tinterpScheme_().interpolate(vsf), name) ); GeometricField<GradType, fvPatchField, volMesh>& gGrad = tgGrad(); // STEP 2: correctBoundaryConditions(vsf, gGrad); return tgGrad; } Step 2: This step adds the non-zeroGradient component to the boundary field, i.e. it is temporary non-zeroGradient! In your code, where you have the line Code:
volVectorField gradT(fvc::grad(T)); // write all component fields If, however, you replace your code by this: Code:
volVectorField gradT(fvc::grad(T)); gradT.correctBoundaryConditions(); // write all component fields Code:
OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/finiteVolume/gradSchemes/gaussGrad/gaussGrad.C I tried to see, whether I could get a fixedGradient in the construction instead, but I was not immediately successful. This does not, however, mean that it is not possible. Kind regards, Niels
February 15, 2014, 15:30 |
Bernhard
Rep Power: 21 |
Aah, I had some suspicion that somewhere a correctBoundaryCondition had to come into play. Thanks for digging into this issue. I will need some time to consider my options to circumvent this feature for my applications
If I come up with any useful implementation, I will obviously share it here. |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Syntax errors with Thread Types and Wall Heat Transfer calculation | jcespada | Fluent UDF and Scheme Programming | 2 | March 16, 2012 02:23 |
Temperature wall function for incompressible solver | Hagen | OpenFOAM | 0 | December 27, 2010 09:25 |
Wall BC's for a NS solver | André Burdet | Main CFD Forum | 6 | December 8, 2000 21:45 |
