Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
probe of mag(U)
Like Tree1Likes
  • 1 Post By Harald
Old   April 2, 2014, 10:36
Default probe of mag(U)
flux is on a distinguished road
i am trying , to probe the magnitude of the U-field at a specific position.
I have already tried the following code in my controldict, but i always get the U-field in components or nothing:
functions {
    probes
        type            probes;
        functionObjectLibs     ("libsampling.so");
        enabled                 true;
        outputControl        timeStep;
        outputInterval       1;
        probeLocations
            (-0.2 -0.05 0)
        fields
        U
        magU
        mag(U)
So what should i do, to get an x-y list of the itaration step and the magnitude of the U field?
Thanks!
flux is offline   Reply With Quote
Old   April 3, 2014, 07:31
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I am not sure if it can be done within the controldict, but this command on the terminal will give you the magnitude of U for each probed timestep:
sed 's/(/ /g' postProcessing/probes/0/U | sed 's/)/ /g' | awk '{print $1 " " sqrt($2*$2+$3*$3+$4*$4)}' >  postProcessing/probes/0/magU
Regards,
Tom
tomf is offline   Reply With Quote
Old   April 9, 2014, 04:10
thx, but i calculated the magnitude with excel^^
Old   April 9, 2014, 07:48
Bernhard
Bernhard is on a distinguished road
Originally Posted by tomf View Post
Regards,
Tom
Your sed commands can be replaced by
tr "()" " "
Bernhard is offline   Reply With Quote
Old   January 25, 2021, 09:08
Harald Radlwimmer
Harald is on a distinguished road
today I faced the same challenge as you did a few years ago. After some elaboration, I managed to calculate the mag(U)-probes directly with OpenFOAM-8.
To do the same, you have to:
1) include the mag(U)-function in controlDict
functions
  #includeFunc  mag(U);
2) get the probes-dictonary (in case you have not got it yet)
foamGet probes
3) define your probe locations in system/probes and add mag(U) to the list
fields (p U mag(U));
probeLocations
    (0 0 0)
4) calculate mag(U)
postProcess -func "mag(U)"
and finally
5) get the probes
postProcess -func probes
In a script, you could also combine (4) and (5) as follows:
for x in mag\(U\) probes
do
runApplication -append postProcess -func "${x}"
done
For steady-state solvers, you may want to add an additionally latestTime-flag to the above commands.
Kind regards,
Harald
ali moeni likes this.
Harald is offline   Reply With Quote
Using Probe for part of a patch ndr OpenFOAM Running, Solving & CFD 7 April 4, 2019 06:26
Line Probe Smoothing badger1 STAR-CCM+ 1 May 21, 2013 22:36
Heat transfer/Temperature along a tube and probe. moienfar-CFD FLUENT 4 March 4, 2013 11:29
new atmospheric probe design manobianco Main CFD Forum 0 May 12, 2012 15:04
functionObject Probe: it's possible to stop and restart? ivan_cozza OpenFOAM Post-Processing 0 September 28, 2010 04:42
