Ali reza
Rep Power: 12 ![]() |
hello everyone
I have got wall shear stress quantities in openfoam220 as you can see here some of them Code:
298) (-0.00127718 -0.000404221 0.000533978) (-0.00121755 -0.000385898 0.000510818) (-0.00121095 -0.000383667 0.000508087) (-0.00121859 -0.000385795 0.000510546) (-0.0012234 -0.000387756 0.000512453) (-0.0088624 -0.0029743 0.00632721) (-0.00306619 -0.00136189 0.00492855)FoamFile { version 2.0; format ascii; class volVectorField; location "4.2"; object wallShearStress; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform (0 0 0); boundaryField { body { type calculated; value nonuniform List<vector> 19650 ( (-0.00122343 -0.00038825 0.000512333) (-0.00123169 -0.00039155 0.000516047) (-0.00122192 -0.000388865 0.000512123) (-0.00121797 -0.000387782 0.000510915) (-0.00124789 -0.000398131 0.000522871) (-0.0012472 -0.000399014 0.000524404) (-0.00121061 -0.000387105 0.000509156) (-0.00121566 -0.000388515 0.000511397) (-0.00122399 -0.000392193 0.000514912) (-0.001237 -0.000396912 0.000520762) (-0.00123446 -0.000395865 0.000520842) (-0.00122043 -0.000390811 0.000514863) (-0.00121514 -0.000389146 0.000512908) (-0.00121446 -0.0003887 0.000512529) (-0.00124398 -0.00039817 0.000525058) (-0.0012495 -0.000399893 0.000529001) (-0.0012086 -0.000386552 0.00051086) (-0.00121413 -0.000388711 0.00051398) (-0.00122184 -0.000391079 0.000517966) (-0.00122445 -0.000391132 0.000519367) (-0.00122053 -0.000389247 0.000517773) (-0.00122377 -0.000390382 0.000519449) (-0.00121272 -0.000386449 0.000514925) (-0.00120642 -0.000384427 0.000511844) (-0.00124813 -0.000397558 0.000530109) (-0.00124509 -0.000395547 0.000528736) (-0.00122044 -0.000387612 0.000519085) (-0.00121903 -0.000386442 0.000518498) (-0.00121971 -0.000385916 0.000518287) (-0.00121488 -0.000383792 0.00051596) (-0.0012114 -0.000382735 0.000514048) (-0.0012084 -0.000381126 0.000512874) (-0.0012037 -0.000379369 0.000510334) (-0.00120198 -0.000378896 0.000509345) (-0.00124765 -0.000392743 0.000528433) (-0.00124696 -0.000391626 0.000526389) ![]() thank you |
Joachim Herb
Rep Power: 21 ![]() |
Does fluent calculate the wall shear stress during postprocessing? If yes, you have to convert the input fields by foamDataToFluent using an appropriate foamDataToFluentDict including all the necessary fields.
Otherwise if fluent should use the values of the wall shear stress calculated by OpenFOAM it might be enough to modify foamDataToFluentDict to include a line for the wall shear stress. The "field number" for fluent seems to be 19, see https://github.com/OpenFOAM/OpenFOAM...nitNumbers.txt and https://github.com/OpenFOAM/OpenFOAM...taToFluentDict |
Ali reza
thank you
I have check whatever you said and everything was the same as you posted so I think fluent calculated wall shear stress during running however I am not sure about that . |
Joachim Herb
According to https://github.com/OpenFOAM/OpenFOAM...umbers.txt#L27 the wall shear stress is in the fluent data file. So you have to convert your shear stress data like the other values of OpenFOAM to fluent. You have to find out, what to add to your foamDataToFluentDict.
Perhaps Code:
wallShearStress 19 |
Burcu Ramazanlı
Rep Power: 6 ![]() |
Hello jherb,
I have a problem regarding the WSS conversion from OpenFOAM to Fluent. Actually, I can obtain WSS results but when I convert the results to Fluent, then WSS values are seen to be zero, although they are not (I write "wallShearStress 19" in foamToFluentDict file). I don't know how to resolve that issue, could you please help me if you have any idea? |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Calculation of Wall Shear Stress | Dave442 | CFX | 36 | July 12, 2016 04:12 |
Wall shear stress distributions | en51nm | STAR-CD | 2 | January 28, 2010 04:42 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
