error - Foam::sigFpe::sigHandler(int) at ??:?
Old   August 21, 2014, 12:43
Default error - Foam::sigFpe::sigHandler(int) at ??:?
aylalisa is on a distinguished road
Dear Foamers,
I try to compute the turbulence intensity (utiliy) and receive an error:
I've tried:
Tu = sqrt(0.3 *mag(Rxx + Ryy + Rzz))/sqrt(sqr(U.component(0))+sqr(U.component(1))+sqr(U.component(2)));
and:
Tu = sqrt(0.3 *mag(Rxx + Ryy + Rzz))/sqrt(mag(sqr(U.component(0))+sqr(U.component(1))+sqr(U.component(2))));
error:
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
 #1  Foam::sigFpe::sigHandler(int) at ??:?
 #2   in "/lib64/libc.so.6"
 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
  at ??:?
 #6  __libc_start_main in "/lib64/libc.so.6"
  at /home/abuild/rpmbuild/BUILD/glibc-2.18/csu/../sysdeps/x86_64/start.S:125
Could somebody help? What's wrong with the division?
Best regards,
Ayla
aylalisa is offline   Reply With Quote
Old   August 25, 2014, 22:56
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Hi Ayla,
Can you be 100% sure that U is non-zero throughout the entire domain?
If you want to make the evaluation more fpe-proof add a
+VSMALL
somewhere in the denominator.
I hope that helps!
Cheers,
Kyle
kmooney is offline   Reply With Quote
Old   August 26, 2014, 13:45
Hi Kyle,
thanks for your answer!
I think the code is wrong anyway.
I've changed it accordingly:
Tu = (sqrt((1/3) * (Rxx + Ryy + Rzz))/stabilise(mag(U),SMALL*UUnits));
I guess entries of R are already divided by rho and units are m2/s2. How could I figure out?
The trace elements of R and the values of mag(U) are good but Tu = 0, why?
Whereas in ParaFoam I can compute Tu with the same formula and Tu is not 0.
Greetings!
Ayla
