Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
sampleDict for streamFunction
Old   November 27, 2014, 19:58
Default sampleDict for streamFunction
Sri
srivatta is on a distinguished road
I am trying to write out stream function values on a 2-d surface. Once the case is done running, I invoke the streamFunction utility. I make sure that the streamFunction file exists in each time directory.
Then I invoke the sample utility. The sampleDict is given here. (I got rid of the headers here)
surfaceFormat vtk;
interpolationScheme cellPoint;
surfaces
testplane
type plane;
basePoint (0 0 0.001);
normalVector (0 0 1);
fields (
streamFunction
After the sample utility is run, the post-processing/surface/time folders show up, but there are no files inside the time directories. Is the "streamFunction" field recognized by the sample utility? If I replace streamFunction with U, p etc, they work.
Thanks,
Srivathsan
srivatta is offline   Reply With Quote
Old   November 28, 2014, 01:44
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
streamFunction utility creates pointScalarField (while p is volScalarField). While sample utility can't sample these kind of fields
Once I've made streamFunctionV (https://bitbucket.org/mrklein/streamfunctionv) which first creates pointScalarField and then interpolates point values into cell values. Basically it's streamFunction with the following addition:
            streamFunctionV = dimensionedScalar("zero", phi.dimensions(), 0.0);
            weight = 0.0;
            const labelListList& cellPoints = streamFunctionV.mesh().cellPoints();
            forAll(streamFunctionV, cellI)
                const labelList& curCellPoints = cellPoints[cellI];
                forAll(curCellPoints, cellPointI)
                    streamFunctionV[cellI] +=
                        streamFunction[curCellPoints[cellPointI]];
                    weight[cellI] += 1.0;
            streamFunctionV /= (weight + 1.0);
            streamFunctionV.boundaryField() = 0.0;
            streamFunctionV.write();
alexeym is offline   Reply With Quote
Old   November 28, 2014, 07:54
Sri
Thank you for your quick reply. I will try this and let you know.
Sri
Old   November 30, 2014, 09:53
Sri
This idea works the way I want it to.
Thank you very much.
sample postprocessing
sampleDict and controlDict musahossein OpenFOAM Post-Processing 39 July 17, 2016 10:00
controlDict and sampleDict giving different results Shenan OpenFOAM Post-Processing 2 November 15, 2014 10:15
Question on sampleDict musahossein OpenFOAM Running, Solving & CFD 8 May 8, 2013 17:48
sampleDict keyword patchName not accepted musahossein OpenFOAM Bugs 6 January 28, 2013 00:48
sampleDict Bug musahossein OpenFOAM Bugs 7 December 12, 2011 12:45
