June 15, 2015, 12:32 |
faceSource function object in parallel?
Damiano Natali
Rep Power: 13 |
Hi Foamers,
has anybody ever had problems with running faceSource function object (useful to average a field on a plane or in a region) in parallel? I'm trying to run a calculation in parallel and the simulation get stuck after solving all the fields, while everything goes smooth in serial. Here is the code snippet in my system/controlDict Code:
faceObj1 { type faceSource; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl timeStep; outputInterval 1; log true; valueOutput false; source sampledSurface; // Type of face source: faceZone, patch sourceName faceObj1; operation areaAverage; sampledSurfaceDict { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { basePoint (0.00025 0 0); normalVector (1 0 0); } source cells; // sample cells or boundaryFaces interpolate false; } fields ( p ); surfaceFormat dx; } Damiano
Damiano Natali Eng Phd | R&D and FEA Engineer ________________________________________ Cressall | Optimum Resistor Solutions Evington Valley Road, Leicester, Leicestershire, LE5 5LZ, UK. NERs | Load Banks | Marine & Offshore | DBRs | Renewables |
November 8, 2018, 08:08 |
Manaf Muhammed
Rep Power: 7 |
i am also facing the same problem if u you have a solution please help
February 1, 2021, 10:54 |
Luiz Oliveira
Rep Power: 7 |
Did you manage to find a solution or a workaround on this problem?
Luiz Oliveira PhD. Student in Environmental Fluid Dynamics University of Napoli: Federico II |
facesource, function object, parallel |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Problem with parallel run | boubou | CFX | 4 | June 10, 2015 04:15 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
