Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Write out sum of face values during/after run?
Old   February 4, 2016, 11:50
Default Write out sum of face values during/after run?
Lennart
elmo555 is on a distinguished road
I'm trying to output the sum of a face value over all cells during runtime or after running the simulation. Within the code, I just do:
Info<< "Total interface area A: " << sum(aInterface).value() << endl;
I'd like to have the same functionality using sampleDict, probes or the controlDict functions, or foamLog (I do not completely understand the difference between these).
A file that contains my value over each time step is what I need, so it can be plotted using gnuplot.
I've tried using the controlDict functions, as described here, like this:
functions
    aInterfaceSum
        type            fieldValue;
        functionObjectLibs ("libfieldValue.so");
        enabled            true;
        outputControl   outputTime;
        log                true;
        valueOutput     false;
        source          patch;
        sourceName        internalField;
        operation       sum;
        fields
            aInterface
I think this should be pretty simple, so any help would be greatly appreciated Thanks!
elmo555 is offline   Reply With Quote
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
