June 13, 2016, 06:54 |
Mapping Values of an internal Field
Louay
Rep Power: 10 |
Hallo Foamers,
i use openFOAM 3.0.1, case solver: interFoam (water air) does anybody know how can i map an internal Field e.g. alpha.water from a case to another one (the two case are linked together with a Patch see my drawing)? I can only map boundary Fields like p_rgh with MapField Utility but i can't map alpha. It would be really helpful for me ! thnx in advance! cheers, | | case1 | | |__Patch___ | | case2 |__________ |
June 13, 2016, 07:28 |
Louay
Rep Power: 10 |
problem solved
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Indentify internal field value at specific patch | Giancarlo_IngChimico | OpenFOAM Programming & Development | 6 | April 16, 2013 12:29 |
solid to fluid heattransfer with chtMultiRegionFoam | nakor | OpenFOAM | 11 | March 21, 2011 08:28 |
Reading field values and setting them as boundary conditions | sega | OpenFOAM Running, Solving & CFD | 1 | July 7, 2009 06:18 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
