August 25, 2016, 02:00 |
Redundant character in output an output file
Taher Chegini
Rep Power: 12 |
Hi all,
I am running a simulation in parallel using compressibleInterFoam solver. The solution is fine but some of the output files have an extra : character instead of a number. For example When I ran reconstroctPar it gave an error complaining that expected a ) sign. When I checked the line of the error, I found out that instead of one of the numbers there is :. For example instead of 291.18 there is :91.18. Any idea what is the problem? |
August 26, 2016, 03:24 |
Taher Chegini
Rep Power: 12 |
Here is an example:
wrong token type - expected Scalar, found on line 430 the punctuation token ':' file: /home/taher/OpenFOAM/taher-4.0/run/geyserCase062DKE/processor3/18.51/U at line 430. Code:
(-0.0069218169 -0.:3684611 0) Last edited by Taataa; August 26, 2016 at 04:54. |
parallel compressible, reconstructpar |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
