How to sample including value of boundary points
Old   April 14, 2017, 17:29
Default How to sample including value of boundary points
TML
TIAN
TML is on a distinguished road
I am running a 2D annular flow case, and I am trying to get velocity distribution at a certain location using sample utility. The problem is that the result gives by sample does not include the boundary point which should be (0 0 0) for a no-slip wall. I have tried cellPoint, cellPointFace, and cellPatchConstrained for the interpolationScheme, but none of them works.
This is my sampleDict:
FoamFile
version 2.0;
format ascii;
class dictionary;
object sampleDict;
setFormat csv;
interpolationScheme cellPatchConstrained;
fields
Ux
sets
lineX1
type uniform;
axis y;
start (0.06 0.02 0); //inner wall
end (0.06 0.03 0); //outer wall
nPoints 40;
Any help is appreciated!
TML is offline   Reply With Quote
Old   April 15, 2017, 01:09
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You let sample calculate the values at a very short perpendicular line which doesn't contain your (0 0 0 ) point.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   April 17, 2017, 10:33
TML
TIAN
Thanks for the reply.
But my start and end point are on the inner and outer wall of the annular cylinder respectively, which should contain the (0 0 0) velocity.
Old   April 17, 2017, 13:27
piu58's Avatar
Uwe Pilz
Please keep in mind: The velocity is modeled, and the last calculated value is the one of the first cell beyond the boundary. Values inside this cell (toward the boundary) are extrapolated.
Beside this it depends form your wall function which velocity you get near the boundary. There is a contradiction between capturing the behavior of the flow very near the boundary and the overall approach of the boundary layer: Both can only covered with DNS.
It may be en-lighting of you look at the velocity at every cell around the cylinder and next the cell toward the flow.
Uwe Pilz
sample
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
