kLowReWallFunction: Enable reporting of yplus |
Rep Power: 9 ![]() |
Hi!
I am running the LaunderSharmaKE-model with kLowReWallFunction. As I understand it, kLowReWallFunction should somehow give the yplus-values, but I cannot find any yplus-values after a simulation, so I guess it have to be enabled somehow. Does anybody know how one can enable reporting of yplus on the walls in my case? Edit: This command seems to work: simpleFoam -postProcess -func yPlus Is it possible to wirte yPlus to cataloges in the same way as for e.g. U? |
I see now that when wiring "simpleFoam -postProcess -func yPlus", there is a new cataloge "yPlus" with the yPlus-values in the postProcessing folder. That's good enough.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
OF 4.0 multiregion case calculate yPlus | pbnuclex | OpenFOAM Post-Processing | 6 | July 16, 2020 04:27 |
which yplus (SST) | sanchezz | CFX | 17 | January 11, 2010 04:45 |
heat transfer coefficients with "bad" yplus | Andrew | Main CFD Forum | 4 | April 8, 1999 04:43 |
