Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
[swak4Foam] weightedAverage using execFlowFunctionObject
Old   April 24, 2017, 12:44
Default [swak4Foam] weightedAverage using execFlowFunctionObject
Andrea Ferrari
Andrea_85 is on a distinguished road
i want to output the weighted average of temperature on a given plane as postProcessing using functionObject (i am using "execFlowFunctionObject -time myTime" to run it as postprocessing). I added these lines to my controlDict:
 surfacePlane
        type swakExpression;
        valueType surface;
        surfaceName testPlane;
        surface {
            type plane;
            basePoint       (0.0040125 1.25e-4 0);
            normalVector    (1 0 0);
            interpolate false;
        verbose true;
        expression "T*area()/sum(area())";
        accumulations (
              sum
However, it seems it does not recognize the field "T". I get this error
--> FOAM FATAL ERROR:
 Parser Error for driver SampledSurfaceValueExpressionDriver at "1.1-2" :"field T not existing or of wrong type"
what am i doing wrong?
i am using openfoam 2.3
Thanks,
andrea
Andrea_85 is offline   Reply With Quote
Old   May 10, 2017, 05:34
Ricky
kera is on a distinguished road
I am not sure what is actually triggering that error, apart from saying that you might be missing "T" field in your time directory :P, as your functionObject worked out fine for me.
I am wondering, is there any reason that you are using this expression
        accumulations (
              sum
and not this
 expression "T";
        accumulations (
              weightedAverage
Regards,
Ricky
Thanks,
andrea
If it is easy, then something is fishy!
kera is offline   Reply With Quote
Old   May 10, 2017, 05:49
Andrea Ferrari
I have actually tried both expressions and got the same error, and yes T-field is in "myTime" directory. If i run the simulation and perform the calculation during the run it works with no problems....
andrea
Old   May 10, 2017, 06:43
Ricky
andrea
then don't load any models. Try to run execFlowFunctionObject in noflow mode
execFlowFunctionObject -noFlow -time yourTime
[swak4Foam] groovyBC boundary using values from another boundary lg88 OpenFOAM Community Contributions 9 July 28, 2017 10:43
[swak4Foam] Trouble accessing fields within expressionField aerogt3 OpenFOAM Post-Processing 6 May 12, 2017 15:02
[swak4Foam] Is it possible to append monitored data in a single file? vasava OpenFOAM Post-Processing 0 February 26, 2016 01:53
[swak4Foam] segmentation faults when using the debug switch "ExpressionResult" Astrodan OpenFOAM Running, Solving & CFD 1 February 21, 2016 16:29
[swak4Foam] different values between swakExpression & faceSource areaAverage Paebin OpenFOAM Community Contributions 7 December 23, 2015 11:29
