Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Unable to sample completed AMI simulation.
Old   May 22, 2017, 13:07
Default Unable to sample completed AMI simulation.
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hello All,
I have completed a long LES simulation (month time) and the simulation seems to be successful with good contour values seen in Tecplot.
but when I try to sample my case as I have previously done with symmetryPlane (worked) it does not work with the AMI case it just stops/gets stuck with the following error (I have waited for over a day still it dosent progress even in parallel it doesnt)
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.0
Exec   : sample
Date   : May 22 2017
Time   : 17:48:16
Host   : "*******"
PID    : 8140
Case   : /mnt/hdd/......../C1A0_StepLES
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
--> FOAM Warning :
    From function void Foam::Cloud<ParticleType>::initCloud(const bool)
    in file lnInclude/Cloud.C at line 54
    Particle tracking across AMI patches is not currently supported
the following is my sampleDict
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      http://www.openfoam.org               |
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
    location        system;
    object          sampleDict;
setFormat raw;
surfaceFormat raw;
interpolationScheme cellPoint;
fields
    k
    UMean
sets
xc02
        type        uniform;
        axis        y;
        start       (0.202 0.3 0.01);
        end         (0.202 -0.3 0.01);
        nPoints     1000;
Any suggestions as to how could I circumvent or solve this issue of extracting line data from my completed simulation,
Thanks,
Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius
Alhasan is offline   Reply With Quote
Old   May 24, 2017, 05:14
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
as the message tells you:
you can program the tracking yourself and make a feature report to OpenFOAM to add the patch to the development line in order that everybody has the possibility to use it. I never used particles and thus, cannot give you more information. It might be that this problem was resolved / added to the development line already but I don't know.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Translating and Rotating AMI HiddenSquid OpenFOAM Pre-Processing 1 October 25, 2017 03:59
[ANSYS Meshing] unable to mesh a 3d airfoil for fluent simulation stacey ANSYS Meshing & Geometry 1 July 8, 2013 03:02
How to save a .res file after simulation completed weihaur CFX 0 April 23, 2008 05:14
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 17:20
about my old post Rogerio Fernandes Brito CFX 1 February 8, 2008 19:19
