How to sample turbulenceProperties:R?
Old   May 24, 2017, 03:07
Default How to sample turbulenceProperties:R?
kaaja is on a distinguished road
Running k-epsilon with simpleFoam I am using "sample" to sample values at certain locations. This works fine for values like U and k, that are generated during run time. However, it does not work for values like, turbulenceProperties:R and wallShearStress, which is generated by the postprocessing functionality.
For the turbulent stress tensor I get the error message
--> FOAM Warning :
    From function Foam::label Foam::sampledSets::classifyFields()
    in file sampledSet/sampledSets/sampledSetsGrouping.C at line 140
    Cannot find registered field matching turbulenceProperties:R
--> FOAM Warning :
My sample-file looks like this
|  \\    /   O peration     | Version:  4.0                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      sampleDict;
type sets;
libs ("libsampling.so");
interpolationScheme cellPointFace;
setFormat raw;
sets
    mu_0101
        type            face;
        axis            z;
        start           (-0.075 0.0875 0.0);
        end             (-0.075 0.0875 0.05);
    mu_0201
        type            face;
        axis            z;
        start           (-0.025 0.0875 0.0);
        end             (-0.025 0.0875 0.05);
fields
    U turbulenceProperties:R
turbulenceProperties:R is generated by
  simpleFoam -postProcess -func R -latestTime
The sample file is run by
simpleFoam -postProcess -func sample -latestTime
"turbulenceProperties:R" exists lik a file just like U and k, so I do not understand why there is a problem sampling it. Does anybody have an idea about how to solve this?
kaaja is offline   Reply With Quote
Old   May 24, 2017, 03:55
I think I solved it, with help from this thread.
One additional thing I needed to do was to remove "simpleFoam" also from the command calling on sample.
It works for turbulenceFields:R also, not only for the components as in the mentioned link.
Old   May 29, 2023, 12:18
Uttam
openfoam_aero is on a distinguished road
which version of OF? i use 1812 and it does not work for me
Best Regards
Uttam
“When everything seem to be going against you, remember that the airplane takes off against the wind, not with it.” – Henry Ford.
openfoam_aero is offline   Reply With Quote
If a sample line coincides with faces, the user should set the set the sample line?? Hojae OpenFOAM 3 November 29, 2014 05:48
Sample issues MikePo OpenFOAM Post-Processing 1 February 7, 2010 19:20
heat conducting in a solid domain Rogerio Fernandes Brito Phoenics 0 March 18, 2008 17:23
heat conducting in a solid domain Rogerio Fernandes Brito Siemens 0 March 18, 2008 17:23
about my old post Rogerio Fernandes Brito CFX 1 February 8, 2008 19:19
