Help with the calculation of dimensional wall distance |
March 27, 2018, 12:11 |
Need help for the calculation of dimensional wall distance
ustam
Hello Foamers,
I need to calculate the dimensional wall distance for each mesh point and write that data as a scalar field into the time directories. To achieve that I have tried writing a custom functionObject, however, I failed to get something going since I am not good at object-oriented programming. If anyone tried this before, I am willing to hear your suggestions. BTW, I am using OpenFOAM v1706. Thanks. Last edited by ustam; March 28, 2018 at 10:22. |
March 28, 2018, 10:27 |
ustam
I found a builtin tool to calculate dimensional wall-distance.
All you need to do is; - find "applications/test/wallDist" directory, - compile using wmake command, - then run it in your case file. Actually, it is even calculating the wall distance for moving mesh as well. |
functionobject, openfoam 17.06(v2), wall distance |
Nearest wall Distance | miz_miz | CFX | 15 | March 2, 2015 14:07 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Dimensionless wall distance | messik | Main CFD Forum | 4 | March 15, 2014 06:55 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
calculation of wall heat flux in CHT | richard | CFX | 1 | July 23, 2009 09:00 |
