Calculate integral length scale with coded functions |
March 18, 2019, 14:38 |
Rep Power: 14 |
atm I had no experience with coded functions. My first try is to produce a scalar field by calculating the integral length scale of an element and divided the result with the element volume. I would be use an RANS simulation with an kOmega turbulence model. my first lines of system/controlDict looks like Code:
functions { calcMeshFactorForLES { type coded; libs ("libutilityFunctionObjects.so"); enabled yes; writeControl timeStep; code #{ // get turbulent kinetic energy const volScalarField& k (???); // get energy dissipation rate const volScalarField& eps (???); // auto integralLengthScale = FOAM::pow(k, 3.0 / 2.0) / eps; // auto volume (???); auto factor = integralLengthScale / FOAM::pow(volume, 1.0 / 3.0); #} } } Thanks. |
March 19, 2019, 08:56 |
Mathias Poulsen
Rep Power: 8 |
Hi Thomas.
I have tried to finish you code. I have not had the time to check if it works, but hopefully it will. Basically you use the mesh().lookUpObject<Type>("VarName") to get different fields from the object registry. If it cant find the name of the variable, un-comment the INFO line, and run the solver, it will show you whats available in the terminal. Code:
functions { calcMeshFactorForLES { type coded; libs ("libutilityFunctionObjects.so"); enabled yes; writeControl timeStep; code #{ // get turbulent kinetic energy const volScalarField& k = mesh().lookupObject<volScalarField>("k"); // get energy dissipation rate const volScalarField& eps = mesh().lookupObject<volScalarField>("epsilon"); // auto integralLengthScale = FOAM::pow(k, 3.0 / 2.0) / eps; // //Info<<mesh().thisbd()<<endl; //print all objects to the terminal const scalarField& volume = mesh_.V(); // Cell volume auto factor = integralLengthScale / FOAM::pow(volume, 1.0 / 3.0); #} } } best regards Mathias |
March 19, 2019, 14:31 |
Rep Power: 14 |
Hi Mathias,
thank you for the quick answer, but a few question remain First of all, I found the codedFunctionObject, that helps a lot. I fixed something Code:
calcMeshFactorForLES { libs ("libutilityFunctionObjects.so"); type coded; name calculateFactorForLESField; codeWrite #{ // get turbulent kinetic energy const volScalarField& k = mesh().lookupObject<volScalarField>("k"); // get energy dissipation rate const volScalarField& eps = mesh().lookupObject<volScalarField>("epsilon"); // auto integralLengthScale = Foam::pow(k, 3.0 / 2.0) / eps; // //Info<<mesh().thisDb()<<endl; //print all objects to the terminal const scalarField& volume = mesh().V(); // Cell volume auto factor = integralLengthScale / Foam::pow(volume, 1.0 / 3.0); //Info << factor << endl; writeToField??? #}; }
March 19, 2019, 15:42 |
Rep Power: 14 |
So, the answer of my last question are solved by my self
For someone that has the same problem Code:
calcMeshFactorForLES { libs ("libutilityFunctionObjects.so"); type coded; name calculateFactorForLESField; codeWrite #{ // get turbulent kinetic energy const volScalarField& k = mesh().lookupObject<volScalarField>("k"); // get energy dissipation rate const volScalarField& eps = mesh().lookupObject<volScalarField>("epsilon"); // auto integralLengthScale = Foam::pow(k, 3.0 / 2.0) / eps; // //Info<<mesh().thisDb()<<endl; //print all objects to the terminal const scalarField& volume = mesh().V(); // Cell volume auto myFactor = integralLengthScale / Foam::pow(volume, 1.0 / 3.0); volScalarField approxCellSizeForLESFactor ( IOobject ( "approxCellSizeForLESFactor", time_.timeName(), mesh(), IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh(), dimensionedScalar("approxCellSizeForLESFactor", dimless, scalar(0.0)) ); approxCellSizeForLESFactor.primitiveFieldRef() = myFactor; approxCellSizeForLESFactor().write(); #}; }
March 21, 2019, 03:17 |
Mathias Poulsen
Rep Power: 8 |
Great work.
Your IOobject and volScalarField approxCellSizeForLESFactor looks correct to me Regarding the calculation of k and epsilon. Assuming that you are using LES, I think you have to look in the literature and find the link between the variables used in LES and RANS simulations. I am not very familiar with LES theory or simulations, so you might want to ask someone with more experience in this field than me. The foam:ow function is basically the same as the pow function used in C++. Say you have where is some scalarField, you would write that as Code:
foam::pow(x,2.0) Best regards Mathias |
March 21, 2019, 13:55 |
#6 | |
Rep Power: 14 |
Thanks Matthias.
The calculated function above is a approximated value to asume mesh size for LES calculation. But you can also use the factor something else. I try to get an universal function that can also handle RANS calculation if k or epsilon is not present. Please correct me, when I wrong. But I think the k & epsilon field in FOAM-RANS is only calculated, when the turbulence model is included the calculation. I think (without test ) calculation with k-omega turbulence model do not include epsilon field. Is a way to force to calculate k & epsilon unindepend the choosen turbulence model in RANS? Or, how I get the needed variables to calculate the shit. |
March 21, 2019, 14:35 |
Rep Power: 14 |
I opened a new thread for epsilon and k calculation.
November 22, 2019, 07:47 |
Jianrui Zeng
Rep Power: 7 |
If I am doing DNS and I want to get k and epsilon after calculation, how should I do?
December 17, 2020, 08:31 |
Integral length scale code not working
#9 |
Sumedh Jain
I used your code to find the meshFactor for LES. Unfortunately, the code executes with a minor error but the factor filed is not being written at all.
OF version - v1912 solver - simpleFoam in postProcess mode Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _f3950763fe-20191219 OPENFOAM=1912 Arch : "LSB;label=32;scalar=64" Exec : simpleFoam -postProcess -parallel -latestTime -decomposeParDict system/decomposeParDict.ptscotch Date : Dec 17 2020 Time : 13:19:03 Host : ip-172-31-5-127 PID : 40150 I/O : uncollated Case : /fsx/Fsx/export/Fsx/OF64_6_fa350 nProcs : 288 Hosts : ( (ip-172-31-5-127 96) (ip-172-31-15-187 96) (ip-172-31-8-42 96) ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 1000 SIMPLE: no convergence criteria found. Calculations will run for 500 steps. --> FOAM Warning : From function virtual bool Foam::functionObjects::codedFunctionObject::read(const Foam::dictionary&) in file codedFunctionObject/codedFunctionObject.C at line 288 Reading "/fsx/Fsx/export/Fsx/OF64_6_fa350/system/controlDict.functions.calcMeshFactorForLES" No critical "code" prefixed keywords found. Please check the code documentation for more details. Using dynamicCode for functionObject calcMeshFactorForLES at line -1 in "/fsx/Fsx/export/Fsx/OF64_6_fa350/system/controlDict.functions.calcMeshFactorForLES" Time = 1000 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; decayControl false; kInf 0; omegaInf 0; } No MRF models present No finite volume options present End Finalising parallel run |
February 25, 2021, 13:54 |
#10 |
Umut Kaya
Rep Power: 5 |
It seems like you couldn't copy the function properly to controldict.
Also try to run it without all the keywords, but the necessary ones: simpleFoam -postProcess -latestTime |
Difference between mixing length and turbulence length scale | MissCFD | CFX | 1 | May 7, 2015 12:58 |
Estimation of turbulence length scale | J.Y.Won | OpenFOAM Pre-Processing | 0 | April 28, 2015 07:16 |
Integral Length Scale vs Turbulent Length Scale | Scott Nordsen | FLUENT | 2 | January 20, 2014 01:17 |
Turbulent length scale setting | realanony87 | CFX | 5 | October 14, 2012 18:03 |
Turbulent Characteristic Length/Turbulent Length Scale | fluentnoob | FLUENT | 2 | July 3, 2009 08:40 |
