Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
interFoam - Volume of Fluid
Like Tree1Likes
  • 1 Post By santiagomarquezd
Old   March 5, 2019, 09:21
Default interFoam - Volume of Fluid
David
Fool is on a distinguished road
Hello everybody,
I have a short and probably quite simple question about the presentation of the results of interFoam in Paraview.
So there are two phases, air and water. To view only the water in Paraview, I use the clip function in conjunction with scalar and set the alpha value to 0.5. What I haven't quite understood yet is what this value stands for? Does this mean that all cells containing at least 50% water are displayed?
In simulations with a finer grid, areas were also displayed in which there was no water according to the coarser grid.
Or is this a clear indication that my grid is too coarse?
Unfortunately, I have not yet found an answer that I can understand.
Thanks a lot.
Dave
Fool is offline   Reply With Quote
Old   March 6, 2019, 09:26
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hello, there is an intrinsic uncertainty in VOF regarding the interface. In cells with 0 < alpha < 1 the cell is not completely filled of water and you don't know which is the shape of the interface and its position. So, yes, the system shows you the cells with at least 0.5 of water. When you refine the solution can change since the NS equation are non-linear.
Regards.
Fool likes this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   April 12, 2019, 10:32
David
what I don't quite understand is:
after using the clip function with 0.5 for alpha.water and then marking the cells and exporting them as a CSV file, alpha.water will display values from 0.14 to 0.69. Shouldn't the values all be between 0.5 and 1.0 if only cells with alpha.water values above 0.5 are displayed?
interfoam, paraview, vof
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
Volume of Fluid method for multiple fluid flows j.patel Main CFD Forum 6 March 7, 2014 22:13
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
fluid hot volume in fluid cold volume zahid FLUENT 4 June 1, 2002 09:11
