Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Change foamLog for Pimple iteration and new variables
Old   April 25, 2019, 09:16
Default Change foamLog for Pimple iteration and new variables
Ilan
Magistrane is on a distinguished road
Dear Foamers,
I need a little help for my post-processing :
I use a solid solver to compute a rotation. For each time step, pimple loop is called several times. In each loop, the variable I need to plot (Angular velocity) through time is calculated.
I need to extract my angular velocity against time. I just need the last value for each time step.
I already used one of the solutions posted on CFD online that used the grep function. But it gives me all the values of the angular velocity independently of the time step.
Then I though i should use foamLog to do that. But 1) the function is not really good working when pimple do more than 1 iteration (create a new file for each variable at a certain number of iteration). 2) It is complicated for me to add a new variable in the code.
In short, I need a file with 2 colomns :
Time step/Last angular velocity of the time step
For this type of file :
Starting time loop
Courant Number mean: 2.8755e-06 max: 0.000106375
deltaT = 5.9988e-06
Time = 5.9988e-06
PIMPLE: Iteration 1
forces forces:
    Not including porosity effects
6-DoF rigid body motion
    Centre of rotation: (8.05317e-08 -1.02214e-07 1.49884e-18)
    Centre of mass: (8.05317e-08 -1.02214e-07 1.49884e-18)
    Orientation: (0.710317 -0.703881 -2.09457e-16 0.703881 0.710317 -1.1383e-15 9.50012e-16 6.61124e-16 1)
    Linear velocity: (0 0 0)
    Angular velocity: (0 0 0)
AMI: Creating addressing and weights between 10320 source faces and 10488 target faces
AMI: Patch source sum(weights) min/max/average = 0.988487, 1.34623, 1.0066
AMI: Patch target sum(weights) min/max/average = 0.371348, 1.06694, 0.998123
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.00954092, No Iterations 5
GAMG:  Solving for pcorr, Initial residual = 0.0082744, Final residual = 0.0082744, No Iterations 0
time step continuity errors : sum local = 6.46058e-06, global = -1.50885e-09, cumulative = -1.50885e-09
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 3.73148e-11, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 5.38785e-06, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.999958, Final residual = 9.5898e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00993448, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.00830228, Final residual = 3.63498e-07, No Iterations 6
time step continuity errors : sum local = 3.62129e-14, global = -1.00253e-14, cumulative = -1.50886e-09
PIMPLE: Iteration 2
forces forces:
    Angular velocity: (-8.46769e-23 -4.6018e-22 4.04268e-07)
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.00949575, No Iterations 5
GAMG:  Solving for pcorr, Initial residual = 0.00827485, Final residual = 0.00827485, No Iterations 0
time step continuity errors : sum local = 6.4601e-06, global = -1.53028e-09, cumulative = -3.03913e-09
smoothSolver:  Solving for Ux, Initial residual = 0.797393, Final residual = 1.90207e-06, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.177599, Final residual = 7.16774e-06, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.193548, Final residual = 4.67921e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.00855496, Final residual = 3.27126e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.00194473, Final residual = 4.22478e-07, No Iterations 5
time step continuity errors : sum local = 4.88858e-14, global = 3.29588e-16, cumulative = -3.03913e-09
PIMPLE: Iteration 22
forces forces:
    Angular velocity: (-7.35178e-23 -3.99535e-22 3.50992e-07)
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.00960231, No Iterations 5
GAMG:  Solving for pcorr, Initial residual = 0.00827486, Final residual = 0.00827486, No Iterations 0
time step continuity errors : sum local = 6.45894e-06, global = -1.51682e-09, cumulative = -3.38869e-08
smoothSolver:  Solving for Ux, Initial residual = 3.51142e-06, Final residual = 7.51302e-12, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1.77977e-07, Final residual = 1.77977e-07, No Iterations 0
smoothSolver:  Solving for Uz, Initial residual = 3.29433e-07, Final residual = 3.29433e-07, No Iterations 0
GAMG:  Solving for p, Initial residual = 2.31852e-07, Final residual = 2.31852e-07, No Iterations 0
time step continuity errors : sum local = 2.83004e-14, global = -9.88155e-16, cumulative = -3.38869e-08
PIMPLE: Converged in 22 iterations
ExecutionTime = 67.58 s  ClockTime = 68 s
Courant Number mean: 1.67388e-07 max: 2.82459e-05
deltaT = 7.19511e-06
Time = 1.31939e-05
PIMPLE: Iteration 1
forces forces:
    Angular velocity: (-2.49876e-22 -1.35796e-21 1.19297e-06)
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 0.00944155, No Iterations 5
GAMG:  Solving for pcorr, Initial residual = 0.00827466, Final residual = 0.00827466, No Iterations 0
time step continuity errors : sum local = 7.74685e-06, global = -1.88339e-09, cumulative = -3.57703e-08
smoothSolver:  Solving for Ux, Initial residual = 0.855398, Final residual = 2.31223e-06, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.208584, Final residual = 6.76758e-06, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.226375, Final residual = 6.68791e-06, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.00386014, Final residual = 2.49145e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.00107462, Final residual = 6.67368e-07, No Iterations 4
time step continuity errors : sum local = 1.29317e-13, global = -1.04586e-14, cumulative = -3.57703e-08
PIMPLE: Iteration 2
Do you have any idea how to do this ?
Thanks guys !
Happy Foam
Magistrane is offline   Reply With Quote
Old   April 26, 2019, 04:26
Ilan
Hello, I found a solution : for any data extraction from OpenFoam logs, you can use this small awk script I wrote :
/Time = /{gsub(")","",$3); if ($1=="Time" && f=="") print $3,0; if ($1=="Time" && f!="") print $3,f}
/Angular velocity:/{gsub(")","",$5);{f=$5}}
First line prints time steps and f.
f is the variable saved in line. It match the data you need to extract (for me, z angular velocity).
foamlog, post processing
