Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foamMonitor after writeNow
Old   August 5, 2019, 08:58
Default foamMonitor after writeNow
Philipp Conen
pconen is on a distinguished road
Greetings to All!
I have a question and hope this is not asked until now.
foamMonitor works perfectly. But when I write the case für the next time step with "writeNow", the simulation ends. When I start the simulation from this point a new folder with the latest saved time steps will be created. When I want to run foamMonitor again I have to change the path to the new folder. But then I could not see all residuals. Only the ones from the latest time step are shown.
Can I use a trick to plot all? Maybe something ling -overwrite?
Greetings
Philipp Conen
pconen is offline   Reply With Quote
Old   August 5, 2019, 09:49
anon_q is on a distinguished road
the functionObject will create a new folder and gives it a name of the start time in
postProcessing/residuals/<startTimeFolder>/residuals.dat
I don't think there is a way to force it to append to the 0 folder of postProcessing/residuals/0 (If I am mistaken, I am curious to know how to do that). But you can try this trick using bash commands:
startTimeFolder=<type the name of the folder e.g: 0.5, don't make spaces between = and the name>
postPath=postProcessing/residuals
cp $postPath/0/residuals.dat $postPath/0/residuals_bak.dat
cat $postPath/$startTimeFolder/residuals.dat >> $postPath/0/residuals.dat
sort $postPath/0/residuals | uniq > $postPath/0/residuals.dat
foamMonitor -l $postPath/0/residuals.dat
Edit: the last line changed to foamMonitor -l $postPath/0/residuals.dat
anon_q is offline   Reply With Quote
Old   August 5, 2019, 11:04
Philipp Conen
Dear Linda,
thank you really much for your fast reply!
I think I understand what these codes are going to do. But I am completly new in OpenFOAM and the hole IT environment. Also I am claculating on a cluster so I am not quite sure how to use ur code. As I know I am working with the bash. So I tryed this:
#!/bin/bash
#PBS -o Channel_PBS_out02.dat
#PBS -j oe
#PBS -q scc-queue3
#PBS -N OpenFoam
#PBS -l nodes=1:ppn=40,walltime=240:00:00
#ulimit -l
cat $PBS_NODEFILE
module unuse /srv/software/modules:/srv/software/modules/all:/srv/software/modules/base:/srv/software/modules/cae:/srv/software/modules/chem:/srv/software/modules/compiler:/srv/software/modules/data:/srv/software/modules/devel:/srv/software/modules/lang:/srv/software/modules/lib:/srv/software/modules/math:/srv/software/modules/mpi:/srv/software/modules/numlib:/srv/software/modules/phys:/srv/software/modules/system:/srv/software/modules/toolchain:/srv/software/modules/tools:/srv/software/modules/vis
module use /srv/software/SCC02/modules/all
module add OpenFOAM/6-foss-2017b
export CORES=96
set -o allexport
source /srv/software/SCC02/software/OpenFOAM/6-foss-2017b/OpenFOAM-6/etc/bashrc WM_COMPILER_TYPE=system WM_COMPILER=Gcc WM_MPLIB=MPI FOAMY_HEX_MESH=yes
set +o allexport
cd /home/ms/p/pc196535/OpenFOAM/Offen/DCLMischer
export LD_PRELOAD=/srv/software/SCC02/software/GCCcore/6.4.0/lib64/libstdc++.so.6
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/srv/software/SCC02/software/GCCcore/6.4.0/lib64/libstdc++.so.6
echo $LD_PRELOAD $WM_PROJECT $WM_PROJECT_DIR $WM_PROJECT_VERSION $FOAM_INST_DIR $WM_COMPILER $WM_MPLIB $FOAM_BASH $FOAM_CSH $WM_LABEL_SIZE
which gcc
startTimeFolder=0.72
#-x LD_PRELOAD
But it does not work.
I tryed to use the Terminal too, but now I dont have my 0 Data anymore.
I would be very thankfull if you can give me some hints on this. Sorry for my missing knowledge.
Greetings
Philipp Conen
Old   August 5, 2019, 11:11
sorry
there was a typo in the last line, it should be corrected to:
and make sure before executing those bash commands that the following folders exist:
  • postProcessing/residuals/0
  • postProcessing/residuals/<your starttime folder>
I guess you can easily understand what the commands above really do: backup the residuals.dat in postProcessing/residuals/0/ folder and try to append to it the residuals.dat from postProcessing/residuals/<startTimeFolder>/residuals.dat and remove the duplicate lines, then you can use that file with foamMonitor
Old   August 6, 2019, 03:33
Kmeti Rao
Krao is on a distinguished road
Originally Posted by pconen View Post
Greetings to All!
Hi Philipp Conen
You can use pyFoamPlotWatcher.py to monitor the residuals. Just write a logfile, and whenever you start the simulation from latest time step, update this log file.
Example:
'simpleFoam >> log.logSimple' this writes the log file, which can be visualized by using 'pyFoamPlotWatcher.py log.logSimple', during the runtime
After you execute the write now and later start with the new time step, again write files using simpleFoam >> log.logSimple, this starts to update the log file, which you can visualise using pyFoamPlotWatcher.py log.logSimple again. Be careful when writing the log file. '>' overwrites the existing logfile and '>>' this updates the existing logfile, therefore use '>>'. I hope you are trying to monitor logs during runtime.
Krao
Krao is offline   Reply With Quote
foammonitor, writenow
DieselFoam does not restart from latestTime lord_kossity OpenFOAM Bugs 8 February 21, 2009 13:54
