Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating mass flow rate through a slice
Old   December 17, 2019, 07:10
Default Calculating mass flow rate through a slice
Maksymilian Kurjata
m.kurjata is on a distinguished road
Hello everyone,
I have a problem regarding the calculation of mass flow rate through a slice of my geometry (a combustion chamber). What I need to examine is recirculation in the inlet area. I won't upload any image of the chamber since the geometry doesn't matter here - the question is general.
I know how to do it in paraview, but this method is too slow for me and I'd like to automatize the whole process.
A different idea was to use a function added to controlDict (it would write data to a file for one slice):
sliceX
type surfaces;
writeControl timeStep;
writeInterval 100;
surfaceFormat vtk;
interpolationScheme cellPoint;
fields (rhoUxMean );
surfaces
interpolatedPlane
type cuttingPlane;
planeType pointAndNormal;
pointAndNormalDict
point (0.0 0.0 0.0);
normal (1 0 0);
triangulate true;
interpolate true;
where rhoUxMean is, of course, a product of the mean density and one component of the Velocity. The data file that's saved in the postProcessing Directory contains Point coordinates (one Point for each cell) and the rhoUxMean value for each point. Unfortunatelly, I can't integrate the mass flow using this data, since I don't know the area of each cell-slice and I can't assume that the area is constant for each of them
Is there any way to solve this problem by modifying the above solution or any other way to efficiently and quickly calculate the mass flow?
I hope my description of the problem isn't too vague.
m.kurjata is offline   Reply With Quote
Old   December 17, 2019, 17:14
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
use flowRatePatch functionObject or something similar.
HPE is offline   Reply With Quote
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
calculating mass flow rate mohit68 FLUENT 2 March 6, 2018 11:54
Calculating mass flow rate at multiphase flows Kuslo187 OpenFOAM Post-Processing 1 August 21, 2015 18:11
mass flow rate... sanjar OpenFOAM Running, Solving & CFD 1 December 2, 2013 00:09
Calculating mass flow rate cfd novice FLUENT 1 April 3, 2008 18:31
