Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallShearStress
Old   January 13, 2020, 06:24
Default wallShearStress
Shai Aser
shaiashe is on a distinguished road
I hope someone will be able to clarify the following;
wallShearStress is calculated as R*n, where R is the stress tensor and n is the surface normal.
When you export wallShearStress on a patch openfoam gives you the data on mesh points.
But points are shared by several faces, which may have different normal orientations. So how do you make sense of the values you get?
Cheers,
shaiashe is offline   Reply With Quote
Finding wallShearStress in dbnsTurbFoam BSengupta OpenFOAM 4 October 21, 2019 21:17
Error computing wallShearStress with simpleFoam sita OpenFOAM Post-Processing 6 November 4, 2018 15:02
wallShearStress vs. force functionObject pad OpenFOAM Post-Processing 2 March 8, 2016 11:24
why does 'sample' do this? wallShearStress question CHARLES OpenFOAM Post-Processing 0 August 7, 2013 19:30
wallShearStress VS wallGradU bigrock OpenFOAM Post-Processing 0 July 2, 2013 05:54
