columnAverage for fields (UMean UPrime2Mean wallShearStressMean) |
January 21, 2020, 06:55 |
niewiemnic
Rep Power: 8 |
I simulate channel flow and I want to do postprocessing with columnAverage. But columnAverage works well with fields (U p); not with fields (UMean UPrime2Mean wallShearStressMean); Code:
columnAverage { type columnAverage; libs ("libfieldFunctionObjects.so"); writeControl writeTime; patches (inout2_half0 inout2_half1); //unten_inlet_outlet //patches (inout1_half0 inout1_half1); fields (UMean UPrime2Mean wallShearStressMean); } |
January 23, 2020, 11:50 |
niewiemnic
Rep Power: 8 |
if I start postProcess -dict system/controlDict -latestTime
OpenFOAM cannot find U p UMean and UPrime2Mean in the result folder, even there are results! Code:
bash-4.2# postProcess -dict system/controlDict -latestTime /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _f3950763fe-20191219 OPENFOAM=1912 Arch : "LSB;label=32;scalar=64" Exec : postProcess -dict system/controlDict -latestTime Date : Jan 23 2020 Time : 16:41:19 Host : 660b166e447b PID : 6029 I/O : uncollated Case : /root/platte/OpenFOAM/halloleute/run/kanal_WALE/kanal_180 nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 4999.97413939496982 Time = 4999.97413939496982 Reading fields: Executing functionObjects --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldSelection::checkSelection() in file functionObjects/fieldSelections/fieldSelection/fieldSelection.C at line 166 Field U not found --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldSelection::checkSelection() in file functionObjects/fieldSelections/fieldSelection/fieldSelection.C at line 166 Field UMean not found --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldSelection::checkSelection() in file functionObjects/fieldSelections/fieldSelection/fieldSelection.C at line 166 Field UPrime2Mean not found --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldSelection::checkSelection() in file functionObjects/fieldSelections/fieldSelection/fieldSelection.C at line 166 Field p not found --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldSelection::checkSelection() in file functionObjects/fieldSelections/fieldSelection/fieldSelection.C at line 166 Field columnAverage:columnAverage(U) not found --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldSelection::checkSelection() in file functionObjects/fieldSelections/fieldSelection/fieldSelection.C at line 166 Field columnAverage:columnAverage(UPrime2Mean) not found --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldSelection::checkSelection() in file functionObjects/fieldSelections/fieldSelection/fieldSelection.C at line 166 Field columnAverage:columnAverage(p) not found --> FOAM Warning : From function virtual bool Foam::functionObjects::fieldSelection::checkSelection() in file functionObjects/fieldSelections/fieldSelection/fieldSelection.C at line 166 Field columnAverage:columnAverage(UMean) not found End |
January 26, 2020, 14:22 |
Damian Berghof
Rep Power: 11 |
Usually I take a detour for such post-processing operations. Assuming the raw data is already available. I import all the data (e.g. CSV) into a python pandas data frame, make the required modifications (statistics) and create a nice output for plotting with matplotlib or ParaView. All this stuff during run-time best, Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups https://bit.ly/2lFfDkQ https://bit.ly/2k2u8Pj |
[General] ParaView skips timeframe for UMean | Max0139 | ParaView | 1 | November 24, 2016 05:29 |
