January 21, 2020, 20:30 |
Heat Flux calculation
Alex
Rep Power: 7 |
I am running a case of Natural convection from a vertical heated flat plate with buoyantBoussinesqPimpleFoam with OpenFOAM 4.x. And beside this, a case with a vertical wavy plate.
I need to quantify the heat flux to evaluate which performs the best. I know that a solution might be to evaluate the local and average Nusselt number of the plates, but my weak coding skill and the too little time available, made me give up to try to build a code to evaluate the Nusselt number along the wall. Is there an alternative way for me to evaluate the heat flux with OpenFOAM? Is it doable to transfer my mesh in CFX and then evaluate there the Nusselt Number? Thanks for the help, I am kind of desperate now. |
January 21, 2020, 21:50 |
Svetlana Tkachenko
Rep Power: 14 |
Can you export the data to Fluent (using foamMeshToFluent and foamDataToFluent) and then open it in CFD-Post?
January 22, 2020, 10:05 |
Alex
Rep Power: 7 |
It might be an idea, but to be honest, I do not know how to do it.
I tried to write in the terminal foamMeshToFluent when I am in the case directory but nothing happended. Could you tell me the steps to follow to convert the mesh and the data? Thank you so much, I am in a very hard situation. |
January 23, 2020, 21:36 |
fluentInterface dir? stdout?
Svetlana Tkachenko
Rep Power: 14 |
Did it not create a directory called 'fluentInterface' in the simulation directory?
Did it say nothing on the screen? Last edited by Светлана; January 23, 2020 at 21:37. Reason: reworded for clarity |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Radiation heat flux calculation | chevalier_b | FLUENT | 0 | August 9, 2013 04:40 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
Heat Flux Wall Boundary Confusion. | Joee | FLUENT | 1 | August 21, 2010 12:20 |
