Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
div function in the postProcess utility gives error
Old   April 5, 2020, 03:13
Default div function in the postProcess utility gives error
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hello guys,
I was taking a look at the postProcess functionality and trying out the new div function to compute the divergence field of the velocity.
I did that quite well by adding the linear scheme to my fvSchemes file:
div(U)      Gauss linear;
However, when I try to use the upwind scheme:
div(U)      Gauss upwind;
I get the following error:
No finite volume options present
--> FOAM Warning :
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 39: label 1
Why is it unable to compute the divergence of U with this scheme (More broadly it cannot be computed by any other schemes except the linear ones)
Best.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   April 5, 2020, 16:24
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Could you please post a MWE, so that we can reproduce the error?
HPE is offline   Reply With Quote
Old   April 6, 2020, 16:26
Mojtaba.a's Avatar
Sure. You can download the attached case.
Reproduce the issue by running the following commands in OF 6:
pisoFoam
postProcess -func "div(U)"
It works fine. Now go to the fvSchemes file and change the div(U) scheme into
Also, you may notice a warning when running the div function where it says it can't find the surfaceScalarField of U. Again, I have no idea why it searches for the surfaceScalarField.
Old   April 9, 2020, 12:48
Mojtaba.a's Avatar
Any thoughts on this?
Old   April 12, 2020, 06:53
HPE
HPE's Avatar
after Easter
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 18:11
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 09:40
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
