April 18, 2020, 02:53 |
parallel run with collate option
I didn't find much on this forum about the collate option of OpenFOAM.
I have the impression it does not speed up the solver, rather the contrary. Does it only exist to allow running on clusters which limit the allowed number of open files? In that case, how to you visualize the results afterwards? Is running foamFormatConvert the only option? In my case it doesn't seem to create any "uncollated" processor*/* folders. And even so, it would probably override the open file limit on the cluster and running locally is most likely unfeasible. This leaves reconstructPar as the best option. Anyone has a better approach to this? I mean reconstructPar means writing the data twice... |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Continuity Equation for multicomponent simulation | lordluan | CFX | 15 | May 19, 2020 18:36 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
