Gui Miotto
Rep Power: 6 ![]() |
Hi guys.
I'm trying to reconstruct an interFoam simulation, but I'm getting a super strange error. If I run a plain reconstructPar, I get: Code:
--> FOAM FATAL ERROR: Not implemented From function virtual Foam::Istream& Foam::ITstream::read(char*, std::streamsize) in file db/IOstreams/Tstreams/ITstream.C at line 159. FOAM aborting I noticed this happens when it tries to reconstruct p_rgh. Therefore, if, for instance, I run: Code:
reconstructPar -fields '(U alpha.water)' ![]() But if I try: Code:
reconstructPar -fields '(p_rgh)' ![]() Any idea what might be causing this? I'm using v1812. This problem does not happen on v7. But if I run interFoam on v1812 and reconstructPar on v7, the error persists. |
Herpes Free Engineer
Rep Power: 12 ![]() |
Can you test
reconstructPar -fields 'p_rgh'
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Gui Miotto
Gui Miotto
Just for completeness, here is the full error message (including stack trace):
--> FOAM FATAL ERROR: Not implemented From function virtual Foam::Istream& Foam::ITstream::read(char*, std::streamsize) in file db/IOstreams/Tstreams/ITstream.C at line 159. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::ITstream::read(char*, long) at ??:? #3 Foam::Istream& Foam::operator>><int>(Foam::Istream&, Foam::List<int>&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #4 Foam::Function1Types::CSV<double>::CSV(Foam::word const&, Foam::dictionary const&) at ??:? #5 Foam::Function1<double>::adddictionaryConstructorToTable<Foam::FieldFunction1<Foam::Function1Types::CSV<double> > >::New(Foam::word const&, Foam::dictionary const&) at ??:? #6 Foam::Function1<double>::New(Foam::word const&, Foam::dictionary const&) at ??:? #7 Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::uniformFixedValueFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #8 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #10 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #11 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #12 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #13 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #14 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #15 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" #16 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #17 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar" |
has been working for my v1812 and v2006 setups, just tested them for "tutorials/heatTransfer/buoyantBoussinesqSimpleFoam/hotRoom". But, your error might be related to one of the boundary conditions in "p_rgh", likely related to "Function1". Could you please share your boundary condition file for "p_rgh", if possible? Thank you.
#6 | |
Gui Miotto
Sure, here it is: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { pres_inlet { type uniformFixedValue; uniformValue { type csvFile; nHeaderLine 19; // number of lines in the header refColumn 0; //time column index componentColumns (1); // pressure column index separator ","; mergeSeparators no; file "$FOAM_CASE/inlet.csv"; } } nozzle { type fixedFluxPressure; value uniform 0; } nozzle_plate_0 { type fixedFluxPressure; value uniform 0; } nozzle_plate_1 { type fixedFluxPressure; value uniform 0; } nozzle_plate_2 { type fixedFluxPressure; value uniform 0; } nozzle_plate_3 { type fixedFluxPressure; value uniform 0; } nozzle_plate_4 { type fixedFluxPressure; value uniform 0; } nozzle_plate_outer { type fixedFluxPressure; value uniform 0; } atm_side { type totalPressure; p0 uniform 0; } atm_bottom { type totalPressure; p0 uniform 0; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class IOobject; object inlet.csv; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // // // DATA SHOULD START ON LINE 20 // 0.000000000000, 8346 0.000040000000, -1849 0.000120000000, 7919 0.000400000000, 10230 0.000840000000, 8381 0.001160000000, -58 0.002960000000, -1862 0.003000000000, 9366 |
I have tested your setup with v1812, and v2006, and it did not produce any error with the command I have suggested. I had a second look at the error message you posted, and it seems the error belongs to OFv7, not v1812. Therefore, I suggest you to issue a bug ticket in the OpenFOAM.org issue tracker for which you can find a link below by attaching your case in your issue ticket, so that they can reproduce the error.
#8 | |
Gui Miotto
Thanks for the suggestion, HPE. The message is indeed from v7, but I get the same thing with v1812. (I'll post later on) One question, do you see anything wrong with the way I'm using the csv? I wondering if I'm doing something that is not allowed by v1812... |
#9 |
"One question, do you see anything wrong with the way I'm using the csv?"
Not so far, but my mind is very tired. ![]()
#10 |
Gui Miotto
I'm now 100% sure that the problem is with v1812. Here are the results of some experiments.
Sadly I have to run my simulations on a cluster (big shout-out to the folks from NEMO hpc), and they only have v1812. So I'm f***. |
#11 |
Gui Miotto
Here is the error raised by decomposePar v1812.
It seems to be related to reading the csv... Code:
--> FOAM FATAL ERROR: Not implemented From function virtual Foam::Istream& Foam::ITstream::read(char*, std::streamsize) in file db/IOstreams/Tstreams/ITstream.C at line 281. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::ITstream::read(char*, long) at ??:? #3 Foam::Istream& Foam::operator>><int>(Foam::Istream&, Foam::List<int>&) at ??:? #4 Foam::Function1Types::CSV<double>::CSV(Foam::word const&, Foam::dictionary const&, Foam::fileName const&) at ??:? #5 Foam::Function1<double>::adddictionaryConstructorToTable<Foam::FieldFunction1<Foam::Function1Types::CSV<double> > >::New(Foam::word const&, Foam::dictionary const&) at ??:? #6 Foam::Function1<double>::New(Foam::word const&, Foam::dictionary const&, Foam::word const&) at ??:? #7 Foam::PatchFunction1<double>::adddictionaryConstructorToTable<Foam::PatchFunction1Types::UniformValueField<double> >::New(Foam::polyPatch const&, Foam::word const&, Foam::word const&, Foam::dictionary const&, bool) at ??:? #8 Foam::PatchFunction1<double>::New(Foam::polyPatch const&, Foam::word const&, Foam::dictionary const&, bool) at ??:? #9 Foam::uniformFixedValueFvPatchField<double>::uniformFixedValueFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #10 Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::uniformFixedValueFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #11 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #12 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #13 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:? #14 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:? #15 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&, bool) at ??:? #16 ? at ??:? #17 ? at ??:? #18 __libc_start_main in /lib64/libc.so.6 #19 ? at ??:? Aborted (core dumped) |
#12 |
Hmm. If you get an error with v1812, and I don't get it with v1812, it only means that we have different instances of v1812. Sometimes, bug fixes are pushed to the previous versions as maintenance activities.
If you are working on a cluster, you can definitely compile your own version (e.g. v1812 or v2006) in your local area. Just consult the cluster maintainers, or the cluster wiki. I am sure that you can do that since I have been doing this for my entire life (in fact, I have never used the system-wide compilations of OpenFOAM in our supercomputer facilities). So, you are definitely not f.cked up, don't worry ![]()
#13 |
Gui Miotto
Dear HPE,
Thanks for your help all the way! Your last post was really an eye opener. I did exactly as you suggested, and it worked! I'm new to this cluster thing, therefore I had to research it a bit, but it was totally worth it. Thanks again. You saved my skin! |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
