reconstructPar super weird error
Like Tree2Likes
  • 1 Post By HPE
  • 1 Post By HPE
Old   June 30, 2020, 11:28
Default reconstructPar super weird error
Gui Miotto
miotto is on a distinguished road
Hi guys.
I'm trying to reconstruct an interFoam simulation, but I'm getting a super strange error.
If I run a plain reconstructPar, I get:
--> FOAM FATAL ERROR:
Not implemented
    From function virtual Foam::Istream& Foam::ITstream::read(char*, std::streamsize)
    in file db/IOstreams/Tstreams/ITstream.C at line 159.
FOAM aborting
(You can check the code for the mentioned function here: https://github.com/OpenFOAM/OpenFOAM...Tstream.C#L157)
I noticed this happens when it tries to reconstruct p_rgh.
Therefore, if, for instance, I run:
reconstructPar -fields '(U alpha.water)'
Everything is fine.
But if I try:
reconstructPar -fields '(p_rgh)'
Then, the error comes up.
Any idea what might be causing this?
I'm using v1812.
This problem does not happen on v7.
But if I run interFoam on v1812 and reconstructPar on v7, the error persists.
miotto is offline   Reply With Quote
Old   June 30, 2020, 15:51
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Can you test
reconstructPar -fields 'p_rgh'
HPE is offline   Reply With Quote
Old   June 30, 2020, 16:12
Gui Miotto
Thanks for the reply, HPE.
Originally Posted by HPE View Post
Can you test
Results in:
--> FOAM FATAL IO ERROR:
incorrect first token, expected <int> or '(', found on line 0 the word 'p_rgh'
I think, the correct syntax is really the one I sent.
Old   June 30, 2020, 16:14
Gui Miotto
Just for completeness, here is the full error message (including stack trace):
Not implemented
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::ITstream::read(char*, long) at ??:?
#3  Foam::Istream& Foam::operator>><int>(Foam::Istream&, Foam::List<int>&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#4  Foam::Function1Types::CSV<double>::CSV(Foam::word const&, Foam::dictionary const&) at ??:?
#5  Foam::Function1<double>::adddictionaryConstructorToTable<Foam::FieldFunction1<Foam::Function1Types::CSV<double> > >::New(Foam::word const&, Foam::dictionary const&) at ??:?
#6  Foam::Function1<double>::New(Foam::word const&, Foam::dictionary const&) at ??:?
#7  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::uniformFixedValueFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#8  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#9  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#10  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#11  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#12  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#13  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#14  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#15  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
#16  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#17  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/reconstructPar"
Old   July 1, 2020, 04:09
HPE
HPE's Avatar
has been working for my v1812 and v2006 setups, just tested them for
"tutorials/heatTransfer/buoyantBoussinesqSimpleFoam/hotRoom".
But, your error might be related to one of the boundary conditions in "p_rgh", likely related to "Function1".
Could you please share your boundary condition file for "p_rgh", if possible?
Thank you.
Old   July 1, 2020, 04:57
Gui Miotto
Thank you.
Sure, here it is:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    pres_inlet
        type            uniformFixedValue;
        uniformValue
            type                csvFile;
            nHeaderLine         19;  // number of lines in the header
            refColumn           0;  //time column index
            componentColumns    (1);  // pressure column index
            separator           ",";
            mergeSeparators     no;
            file                "$FOAM_CASE/inlet.csv";
    nozzle
        type            fixedFluxPressure;
        value           uniform 0;
    nozzle_plate_0
        value           uniform 0;
    nozzle_plate_1
        value           uniform 0;
    nozzle_plate_2
        value           uniform 0;
    nozzle_plate_3
        value           uniform 0;
    nozzle_plate_4
        value           uniform 0;
    nozzle_plate_outer
        value           uniform 0;
    atm_side
        type            totalPressure;
        p0              uniform 0;
    atm_bottom
        type            totalPressure;
        p0              uniform 0;
    defaultFaces
        type            empty;
And here is an example of the inlet.csv file:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       IOobject;
    object      inlet.csv;
//   DATA SHOULD START ON LINE 20
0.000000000000, 8346
0.000040000000, -1849
0.000120000000, 7919
0.000400000000, 10230
0.000840000000, 8381
0.001160000000, -58
0.002960000000, -1862
0.003000000000, 9366
Old   July 1, 2020, 08:11
HPE
HPE's Avatar
I have tested your setup with v1812, and v2006, and it did not produce any error with the command I have suggested.
I had a second look at the error message you posted, and it seems the error belongs to OFv7, not v1812.
Therefore, I suggest you to issue a bug ticket in the OpenFOAM.org issue tracker for which you can find a link below by attaching your case in your issue ticket, so that they can reproduce the error.
Old   July 1, 2020, 08:46
Gui Miotto
Thanks for the suggestion, HPE.
The message is indeed from v7, but I get the same thing with v1812. (I'll post later on)
One question, do you see anything wrong with the way I'm using the csv? I wondering if I'm doing something that is not allowed by v1812...
Old   July 1, 2020, 09:29
HPE
HPE's Avatar
"One question, do you see anything wrong with the way I'm using the csv?"
Not so far, but my mind is very tired.
miotto likes this.
Old   July 1, 2020, 09:43
Gui Miotto
I'm now 100% sure that the problem is with v1812. Here are the results of some experiments.
  • if I run decomposePar, interFoam and reconstrucPar all on v7, no problems occur.
  • if I run decomposePar, interFoam and reconstrucPar all on v2006, also no problems occur.
  • if I try to run decomposePar, interFoam and reconstrucPar all on v1812, I can't get passed the decomposePar, because it raises this "Not implemeted error"
  • if I run decomposePar on v7 and interFoam on v1812, then reconstrucPar will raise the error on both v7 or v1812.
In other words, as long as v1812 is in the mix, it will break everything.
Sadly I have to run my simulations on a cluster (big shout-out to the folks from NEMO hpc), and they only have v1812. So I'm f***.
Old   July 1, 2020, 09:48
Gui Miotto
Here is the error raised by decomposePar v1812.
It seems to be related to reading the csv...
Not implemented
    in file db/IOstreams/Tstreams/ITstream.C at line 281.
FOAM aborting
#3  Foam::Istream& Foam::operator>><int>(Foam::Istream&, Foam::List<int>&) at ??:?
#4  Foam::Function1Types::CSV<double>::CSV(Foam::word const&, Foam::dictionary const&, Foam::fileName const&) at ??:?
#6  Foam::Function1<double>::New(Foam::word const&, Foam::dictionary const&, Foam::word const&) at ??:?
#7  Foam::PatchFunction1<double>::adddictionaryConstructorToTable<Foam::PatchFunction1Types::UniformValueField<double> >::New(Foam::polyPatch const&, Foam::word const&, Foam::word const&, Foam::dictionary const&, bool) at ??:?
#8  Foam::PatchFunction1<double>::New(Foam::polyPatch const&, Foam::word const&, Foam::dictionary const&, bool) at ??:?
#9  Foam::uniformFixedValueFvPatchField<double>::uniformFixedValueFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#10  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::uniformFixedValueFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#11  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#12  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#13  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:?
#14  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:?
#15  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&, bool) at ??:?
#16  ? at ??:?
#17  ? at ??:?
#18  __libc_start_main in /lib64/libc.so.6
#19  ? at ??:?
Aborted (core dumped)
Old   July 1, 2020, 11:08
HPE
HPE's Avatar
Hmm. If you get an error with v1812, and I don't get it with v1812, it only means that we have different instances of v1812. Sometimes, bug fixes are pushed to the previous versions as maintenance activities.
If you are working on a cluster, you can definitely compile your own version (e.g. v1812 or v2006) in your local area. Just consult the cluster maintainers, or the cluster wiki. I am sure that you can do that since I have been doing this for my entire life (in fact, I have never used the system-wide compilations of OpenFOAM in our supercomputer facilities). So, you are definitely not f.cked up, don't worry .
miotto likes this.
Old   July 2, 2020, 11:31
Gui Miotto
Dear HPE,
Thanks for your help all the way!
Your last post was really an eye opener. I did exactly as you suggested, and it worked! I'm new to this cluster thing, therefore I had to research it a bit, but it was totally worth it.
Thanks again. You saved my skin!
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
