How to get stress on a wall from the wind
Old   August 1, 2020, 07:29
Default How to get force on a wall from the wind
LE GARREC Vincent
bansan is on a distinguished road
I run the example windAroundBuildings. I now have the U (x, y, z) and p.
My question is simple : how can I have the pressure on the wall ? I try to use the x projection of the pressure. But on the wall, the pressure is vertical so I don't have any horizontal effort.
Can you explain me how can I compute the pressure on the wall ?
I'm civil engineering, not a physician so maybe it's a formula I don't know.
Thanks for any advice,
Vincent
Last edited by bansan; August 3, 2020 at 05:54. Reason: It's force I need more than stress
bansan is offline   Reply With Quote
Old   August 3, 2020, 03:55
Vignesh S P
VigneshSP is on a distinguished road
Hi bansan,
I would recommend you to use "forces" function object and you can get the force on the patches directly and write it as a field.
for Openfoam v2006 : https://www.openfoam.com/documentati...es-forces.html
for Openfoam V8 :
https://cpp.openfoam.org/v8/classFoa...1_1forces.html
example video:
https://youtu.be/LFn7ti4nCm8
VigneshSP is offline   Reply With Quote
Old   August 3, 2020, 05:56
LE GARREC Vincent
Thanks, it's almost what I wanted. But instead of the sum, do you know if it's possible to have the force in each node of the mesh ?
Old   August 3, 2020, 08:35
LE GARREC Vincent
A found a trick to get force at every point.
In file src/functionObjects/forces/forces/forces.C, in function void Foam::functionObjects::forces::applyBins, I add
forAll(fN, i)
  Log << "fN, fT, fP, d : " << fN[i] << " " << fT[i] << " " << fP[i] << " " << d[i] << endl;
I just have to do the sum (fN+fT+fP) manually.
It's a hack but that do the job. Thanks again for your help.
Old   August 3, 2020, 08:47
Smile
Vignesh S P
Glad to help, best wishes
Wall shear stress for solid phase? qi.yang@polimi.it OpenFOAM Programming & Development 0 February 24, 2020 06:26
Export Wall Shear Stress Data trooken FLUENT 6 February 5, 2019 15:09
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 06:41
Problems with wall shear stress. xiexiehezuo FLUENT 1 September 22, 2009 12:26
