Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Integration of wallShearStress over the surface of a body
Old   December 27, 2020, 14:04
Smile Integration of wallShearStress over the surface of a body
Icaro Amorim de Carvalho
PenPencil is on a distinguished road
Hi all,
I was wondering if you could help me integrate the shear stress over the surface of a 2D body. The problem is that of an incompressible, laminar and unsteady flow of a Newtonian fluid with a Gmsh-generated mesh.
First, I calculated the wall shear stress by the following:
pimpleFoam -postProcess -func wallShearStress
Second, I tried:
postProcess -func 'patchIntegrate(name=cylinder1,wallShearStress)'
to integrate the wall shear stress over my patch 'cylinder1'. As a result, I have gotten the directory postProcessing/patchIntegrate\(name\=cylinder1\,wallShearStress\) with a '.dat' file. I believe my procedure is not correct, since a vector was written in the '.dat' file, as opposed to finding the result of \int\tau \text{ d}A which is a scalar.
However, I have not figured out how to properly do this. Could anyone help, please?
Notes:
1 - I gather Paraview usually is a solution to this as well from older threads, but I intend to use a script and Paraview would not fit into my purposes. But indeed, my calculation does not have to be done using some built-in function of OpenFOAM, as I could post-process elsewhere, provided I had the lengths/areas corresponding to the wall shear stress on each edge of the mesh.
2 - Undoubtedly, OpenFOAM API library and C++ are quite useful in situations like this one, but I am not experienced in them (and to be honest, this is probably the one time in my research that this knowledge would be useful to me, which explains why I haven't felt motivated to learn them...). If you could help me with a solution other than those involving this, I would be most grateful!
Thank you so much
Best regards,
I.
PenPencil is offline   Reply With Quote
integral, openfoam, shear, surface
[ANSYS Meshing] Surface body issue D0ubleU ANSYS Meshing & Geometry 0 April 29, 2016 04:46
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[DesignModeler] Smaller surface body from face bongbang ANSYS Meshing & Geometry 1 June 29, 2015 02:28
[DesignModeler] Boolean Subtract of a body and a surface KrishnaSandeep ANSYS Meshing & Geometry 2 April 1, 2015 15:55
Free surface and moving body Steve Siemens 4 August 20, 2004 11:06
