Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to check y+ values
Old   February 1, 2021, 12:13
Default How to check y+ values
Bergil
Berg is on a distinguished road
I am new in OpenFoam, and I have just run a program to simulate the flow around a tractor. In my model the tractor is stationary
whilst the inlet and ground are moving backwards at 20m/s.
I just run a code I found on the internet called Allrun which uses a k-e turbulence model. And now I would like to check the y+ values but I don't know how to do it. I have run this sequence: simpleFoam -postProcess -func yPlus – but this message appears:
SIMPLE: no convergence criteria found. Calculations will run for 100 steps.
--> FOAM Warning :
From function static bool Foam::functionObjectList::readFunctionObject(const Foam::string&, Foam::dictionary&, Foam::HashSet<>&, const Foam::word&)
in file db/functionObjects/functionObjectList/functionObjectList.C at line 246
Cannot find functionObject file yPlus▒
Can anyone help me? where can I found the yplus values?
Berg is offline   Reply With Quote
Values for nu t and nu tilda Phizz82 OpenFOAM Running, Solving & CFD 1 March 2, 2020 06:00
How can values of profile(k, epsilon) not change? minque FLUENT 4 January 22, 2020 14:14
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
how do you check values at different iteration Gui CFX 5 August 8, 2007 11:33
how to check absolute velocity values gaurav FLUENT 7 May 17, 2004 17:07
