How to write the sampled field values of a curved internal surface?
Old   July 15, 2021, 12:51
Default How to write the sampled field values of a curved internal surface?
Lewis
cfdcheckers is on a distinguished road
I am trying to sample the field values on an internal curved surface. The way I managed to sample the values was using the function object surfaceInterpolate in controlDict. For this I created a dummy surface where I needed the sampling and defined it as "empty" physical surface, and correspondingly making it empty in each 0 folder files.
functions
    dummySurfaceData
        type            surfaceInterpolate; //surfaceFieldValue;
        libs            ("libfieldFunctionObjects.so");
        writeControl    writeTime;
        writeFields     true;
        surfaceFormat   raw;
        regionType      faceZone; //faceZone;
        name            dummySurface;
        operation       none;
        fields
            (p pNear) (T TNear) (U UNear)
If I open the results in paraview I can see the data on the faceZone but I did not find any file written for the dummySurface field values in the case folder. All I see is the pNear, TNear and UNear files in the time folders but the entries for the dummySurface are none in those.
So am wondering if there's any way I can write these sampled field values to a (csv) file?
cfdcheckers is offline   Reply With Quote
Old   July 15, 2021, 13:31
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You may define lines where you get the results. Here an example:
setFormat raw;
surfaceFormat raw;
type    sets;
libs    ("libsampling.so");
interpolationScheme cellPoint;
fields (   U  ); // Fields to sample.
sets (
    w0 {  type lineUniform; axis distance; nPoints 500;
       start (  -0.03 0  0 );
       end (  -0.06 0  0 );
    w5 {  type lineUniform; axis distance; nPoints 300;
start (  -0.0295442 0.00520945  0 );
end (  -0.0413619 0.00729324  0 );
    w10 {  type lineUniform; axis distance; nPoints 300;
start (  -0.0281908 0.0102606  0 );
end (  -0.0394671 0.0143648  0 );
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 15, 2021, 15:21
Lewis
Thanks Uwe for a quick example. I just tried this, in my case it will probably be arcUniform type. However, this method requires me to use start and end angle values. This will not be very convenient when I have changes in the dimensions. I intend to do multiple simulations by changing cylinder diameters. That's why a defined patch name would be very convenient, I thought.
Additionally, I do not want to specify number of cells manually.
Any way out in that case?
Old   July 17, 2021, 10:28
Lewis
Ok, I tried to parameterise it so that it makes a little more convenient.
But it seems mag(U) is not recognised now. Strange. On the forum it doesn't seem like it's been noticed in recent times.
Update: I realised why. It couldn't recognise the field because it doesn't exist! Found an easy way to tackle this by including #includeFunc mag(U) in controlDict
curved surface, cylinder, functionobject, sampling, sampling data
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 18:28
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 18:19
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 07:30
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
