March 4, 2021, 16:52 |
sampleDict error Version 8
Rep Power: 5 |
Hello guys,
I`m running some simulations on a cluster with v8 OpenFOAM. I`m using a sampleDict file to output temperature of different points but i get this error Code:
Create mesh for time = 0 --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 871 Caught FatalError --> FOAM FATAL ERROR: Unknown sample set type cloud Valid sample set types : 14 ( arcUniform boundaryPoints boundaryRandom boxUniform cellSet circleRandom faceSet lineCell lineCellFace lineFace lineUniform points sphereRandom triSurfaceMesh ) From function static Foam::autoPtr<Foam::sampledSet> Foam::sampledSet::New(const Foam::word&, const Foam::polyMesh&, const Foam::meshSearch&, const Foam::dictionary&) in file sampledSet/sampledSet/sampledSet.C at line 176. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open Source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object sampleDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // type sets; libs ("libsampling.so"); writeControl adjustableRunTime; writeInterval 0.2; setFormat csv; surfaceFormat vtk; interpolationScheme cellPoint; fields ( T ); sets ( Centerline { type cloud; axis xyz; points ( (0.00005 0.0000005 0.00005) (0.00005 0.00005 0.00005) (0.00005 0.0000995 0.00005)); } ); surfaces (); // *********************************************************************** // Does anybody know what`s the issue here, or have any suggestion on how to solve it? Thank you!! |
March 16, 2021, 21:01 |
abdikerim kurbanaliev
Rep Power: 15 |
Please use type points instead of type cloud;. I had the same problem, when used type points in openFoam7. All the best, Kerim |
March 17, 2021, 13:32 |
Rep Power: 5 |
Thanks for your reply kerim!!
I tried your suggestion but i get this error now: Code:
--> FOAM FATAL IO ERROR: keyword ordered is undefined in dictionary "controlDict/functions/sampleDict/sets" file: controlDict/functions/sampleDict/sets from line 10 to line 10. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 802. Thank you! |
July 21, 2021, 05:05 |
Rep Power: 5 |
I have the same problem. Did anyone solved it?
sampleDict error | KateEisenhower | OpenFOAM Post-Processing | 5 | October 18, 2021 13:39 |
postProcess -func sampleDict does not create output folder | tmr2044 | OpenFOAM Post-Processing | 7 | April 27, 2021 14:33 |
Does sampleDict have limitation in number of fields? | reza2031 | OpenFOAM Post-Processing | 3 | April 22, 2020 13:24 |
How Coorectly Run sampleDict | FlyBob91 | OpenFOAM Post-Processing | 5 | September 13, 2017 04:01 |
controlDict and sampleDict giving different results | Shenan | OpenFOAM Post-Processing | 2 | November 15, 2014 10:15 |
