Probes - Ux, Uy, Uz or UMagnitude at a specific point |
November 4, 2021, 03:51 |
Mary
Rep Power: 4 |
After the simulation of Time 4000, I would like to know what the Ux, y, z and U Magnitude at a specific point of my geometry, such as (x, y, z)=(0.05, 100, 1.20). I know only probes function: During the processing of simpleFoam, Code:
$foamGet probes Code:
points ( (0.05 100 1.20) (4.05 0 2.50) // ....I have to represent total 51 points ); fields (U); Code:
$foamMonitor -l postProcessing/probes/0/U & All I want to know is U values of 51 points only at the latest time (Time 4000). How can I represent it? Thanks! |
November 18, 2021, 08:22 |
Diego Ferrando
Rep Power: 9 |
Hello Mary,
What you can do is just to run the following command at the end of your simulation and once it is reconstructed (in case of parallel computing) Code:
postProcessing -latestTime -func probes This command will run the probes dictionary you have created and it will run it only for the latest time of your simulation. It will create a file under "postProcessing/probes/4000/U" where you will find the coordinates of your probes and below them the values of the velocity vector. The format is a bit strange and to treat it is better to use python. I hope I have helped you. |
December 1, 2021, 11:02 |
Rep Power: 8 |
You could alternatively use paraview. You have to choose the points either manually, or along a surface or line if you do it this way though
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Continuity Equation for multicomponent simulation | lordluan | CFX | 15 | May 19, 2020 18:36 |
Ansys Fluent: How can I start drawing XY PLOT from a specific point? | RawadSy | FLUENT | 0 | November 6, 2019 13:51 |
[OpenFOAM] Annotate velocity of specific cell or point | jwstolk | ParaView | 4 | August 5, 2016 05:50 |
