visualize materials independently in a mergedMesh |
June 29, 2023, 07:28 |
Julia Docampo
Rep Power: 12 |
Hello
I am trying to post-process a solution consisting of two bodies in contact using the tutorial "punch" in solids4foam: punch.png 1. identify contact regions, loads, etc. 2. generate two meshes 3. mergeMeshes to have a single mesh 4. assign material properties to mesh using setCells Although the mesh is merged, we still know the cells corresponding to each region (body1 & body 2). If I visualize it in paraview, I can only select boundary patches independently: paraview.png Is there a way to retrieve the original bodies (from the cellSets) and visualize independently body1 and body2 ? I apologize if the answer is obvious. I have tried using splitMeshRegions -cellSet. It produces the regions inside the solution folder (1 in my case) but it doesn't assign the computed field values (displacement, stress) to each one so I can only visualize the meshes. Many thanks !!! |
mergedmeshes, multibody, multimaterial, paraview, post-processing |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Adding material to CFX material library | marlon | CFX | 2 | October 16, 2016 09:33 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
