June 11, 2022, 06:25 |
foamToVTK error
Nicola Michielon
Rep Power: 3 |
Hi everyone!
I'am a new user of the forum. Firstly, I would like to show you my appreciation for this website since it has helped me a lot sincee the beginning of my journey in openFoam/CFD. I am student currently working on a thesis about flow simulations around an f1-2022-like car. I am running the simulations on the university cluster and I have completed my first simulation lately. I am trying to visualize the results in paraview locally, on my computer, so I ran foamToVTK on the cluster but it does not complete all the time steps. The simulations has 15 time steps but foamToVTK stops at the fourth one. I have no clue why is doing this, so if anyone is willing to help me I would highly appreciate it. My guess is that is something related to the dimension of the files (" void vtkWriteOps double" - double precision?). In controlDict I am using the following: writeFormat ascii; writePrecision 12; writeCompression compressed; What do you think? /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : dev-69858a80ec41 Exec : foamToVTK Date : Jun 11 2022 Time : 04:30:12 Host : "cm004.hpc.nyu.edu" PID : 1092320 I/O : uncollated Case : /scratch/nm3584/openfoam-test/formula4/formula3 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Time: 0 volScalarFields : p nut k omega volVectorFields : U Internal : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/formula3_0.vtk" Original cells:8841237 points:9911068 Additional cells:9288785 additional points:795265 Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/frontAndBack/frontAndBack_0.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/inlet/inlet_0.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/outlet/outlet_0.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/lowerWall/lowerWall_0.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/upperWall/upperWall_0.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/F1-75/F1-75_0.vtk" Time: 100 volScalarFields : p nut k omega volVectorFields : U Internal : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/formula3_100.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/frontAndBack/frontAndBack_100.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/inlet/inlet_100.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/outlet/outlet_100.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/lowerWall/lowerWall_100.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/upperWall/upperWall_100.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/F1-75/F1-75_100.vtk" surfScalarFields : phi Time: 200 volScalarFields : p nut k omega volVectorFields : U Internal : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/formula3_200.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/frontAndBack/frontAndBack_200.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/inlet/inlet_200.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/outlet/outlet_200.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/lowerWall/lowerWall_200.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/upperWall/upperWall_200.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/F1-75/F1-75_200.vtk" surfScalarFields : phi Time: 300 volScalarFields : p nut k omega volVectorFields : U Internal : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/formula3_300.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/frontAndBack/frontAndBack_300.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/inlet/inlet_300.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/outlet/outlet_300.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/lowerWall/lowerWall_300.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/upperWall/upperWall_300.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/F1-75/F1-75_300.vtk" surfScalarFields : phi Time: 400 volScalarFields : p nut k omega volVectorFields : U Internal : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/formula3_400.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/frontAndBack/frontAndBack_400.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/inlet/inlet_400.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/outlet/outlet_400.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/lowerWall/lowerWall_400.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/upperWall/upperWall_400.vtk" Patch : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/F1-75/F1-75_400.vtk" surfScalarFields : phi Time: 500 volScalarFields : p nut k omega volVectorFields : U Internal : "/scratch/nm3584/openfoam-test/formula4/formula3/VTK/formula3_500.vtk" #0 Foam::error:: printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::vtkWriteOps::insert(double, Foam:: DynamicList<float, 0u, 2u, 1u>&) at ??:? #4 void Foam::vtkWriteOps::write<double>(std:: ostream&, bool, Foam:: DimensionedField<double, Foam::volMesh> const&, Foam::vtkMesh const&) in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/foamToVTK" #5 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/foamToVTK" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/foamToVTK" /scratch/work/public/apps/openfoam/20220221/run-openfoam-dev-paraview56_20220221.bash: line 27: 1092301 Floating point exceptionsingularity exec $nv --overlay /scratch/work/public/singularity/openfoam-dev-paraview56_20220221-depends.sqf:ro /scratch/work/public/singularity/openfoam-dev-paraview56_20220221.sif /bin/bash -c " source /ext3/openmpi-env.sh source /opt/openfoam-dev/etc/bashrc export PATH=.:\$PATH export LD_LIBRARY_PATH=/opt/slurm/lib64:\$LD_LIBRARY_PATH $args " |
June 14, 2022, 03:54 |
Mark Olesen
Rep Power: 40 |
Floating point exception sounds like there might be some interpolation happening that provokes a divide-by-zero error (just a wild guess based on the error message).
If you have access to any recent www.openfoam.com version (current latest is v2112), it would be interesting to see if the problem also exists there. In this version, the VTK conversion is handled using a completely different infrastructure (also supports vtu,vtp,vtm output). Another thing to try might be foamToEnsight. The ensight case files can also be opened in paraview. |
June 14, 2022, 04:09 |
#3 | ||
Nicola Michielon
Rep Power: 3 |
I'll give it a try and let you know, thanks! |
June 14, 2022, 04:43 |
#4 | |
Mark Olesen
Rep Power: 40 |
I was referring to a release of the www.openfoam.com version (OpenCFD Ltd.) whereas your headers indicate you have the www.openfoam.org version (OpenFOAM Foundation Ltd.) - not quite the same thing. You can also visit my blog post (https://olesenm.github.io/2020/11/11...de-provenance/) for some background. |
June 25, 2022, 06:35 |
#5 | |
Nicola Michielon
Rep Power: 3 |
I was able to solve my issue, most likely caused by some "bugs" (holes) in my geometry. |
May 16, 2023, 10:47 |
Ludovico
Rep Power: 4 |
foamtovtk |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
