June 28, 2022, 18:35 |
Lift magnitude out of range.
Rep Power: 4 |
Using pimplefoam on a custom fan mesh:
post-processing in paraview following tutorial process in other posts: -extract block -extract surface -generate surface normals -calculator w/ (p*normals) **note density not here....would just make lift magnitude even higher. -integrate my pressure magnitudes are wildly high (-5.6E6 to 4.9E6) U velocities are unusually low..... I feel like I've missed something essential at the solver level. I have seen that for incompressible solutions p=p/rho.... but that small scaling (1.121 kg/m3) won't correct an E6 magnitude error... The solution is non-physical (nearly stationary fluid, high pressures, and high velocities near the surface) even though the solver worked along for hours in a stable fashion. |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Lift and Drag at Transonic Speeds are Orders of Magnitude from realistic values | ssa44 | FLUENT | 0 | March 22, 2021 15:51 |
Analysing Lift for NACA0012 through range of angles of attack. | wrb | ANSYS | 1 | March 6, 2018 08:33 |
AMI memory leak? | MichiB | OpenFOAM Programming & Development | 14 | August 1, 2015 18:18 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
