Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
paraFoam crashes in loading polyhedral mesh
Old   July 5, 2022, 11:10
Default paraFoam crashes in loading polyhedral mesh
Ramkumar
Ramkumar21194 is on a distinguished road
hello all!
Recently I compiled OpenFOAM v2206 along with ParaView 5.10 that comes with it, on a Ubuntu 22.04 machine. Then I prepared a simulation case setup in which I used snappyHexMesh to generate the mesh, when i try to visualize the mesh in ParaView using command
paraFoam
, ParaView immediately crashes. To understand what is the issue, I created a foam file using
touch case.foam
and tried loading it in ParaView using command
paraview case.foam
. There i was able to visualize the mesh properly.
To narrow down further, i tried loading the background mesh that was created using blockMesh containing only pure hex cells, using
paraFoam
, and i was able to load/visualize it there. So, the issue is that, paraview was able to load mesh with polyhedral cells but paraFoam crashes when loading it, but paraFoam works fine with pure hex mesh. I guess it is something to do with PVFoamReader.
I think this is not a bug, but something i am missing during compilation. Because, if it was a bug, then i am sure that some of you might have caught it long before me. I couldn't find any others reported something like this on forums and other community places, so i came here.
For your reference, I have attached https://filebin.net/hsqkrmxcndqlaox4 log file which is made during ParaView compilation and, "log.postRun.zip" this log is made during second run of ./Allwmake after compiling paraview. and "log.paraFoam.zip" this is the log of error output that i got when paraFoam crashes.
FYI, i need paraFoam for my work, as those plugins i get with are very helpful. otherwise i could have gone for regular paraview. I followed all the steps mentioned in the user guide for compilation.
Could anyone please help me in fixing this issue?.
Ramkumar21194 is offline   Reply With Quote
parafoam crash, paraview, polymesh, snappyhexmesh
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
Foam crashes due to bug or dodgy mesh, or something else? unsteady-eddie OpenFOAM 3 January 19, 2019 12:56
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Polyhedral Mesh Quality in Star-CCM+ niazaliahmed STAR-CCM+ 3 March 8, 2012 13:51
