Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to extract roll angles of 2D floating object?
Like Tree6Likes
  • 6 Post By CKH
Old   February 14, 2012, 11:46
Default How to extract roll angles of 2D floating object?
CKH
Kie Hian
CKH is on a distinguished road
Hi Foamers,
I'm trying to figure out how to extract / sample the roll angle of a floating box constrained to roll only (1 DoF). It seems like a simple problem but I can't seemed to find anyway of doing it!
The case I'm running is based on: Jung, K.H., Chang, K.A., Jo, H.J., Viscous Effect on the Roll Motion of a Rectangular Structure, J. of Engineering Mechanics, 2006. This was mentioned in the Eric Paterson's slides for 3rd OF workshop and seems to have been used as a demo case a few times. If anyone has ran the case before please do share some hints.
Thanks in advance.
Kie
CKH is offline   Reply With Quote
Old   February 15, 2012, 23:05
Default Get sixDoFRigidBodyMoton functionObject to output "Orientation"
CKH
Kie Hian
Posting my work-around if it's of help to anyone else:
Go to $FOAM_SRC/postProcessing/functionObjects/forces/pointPatchFields/derived/sixDoFRigidBodyMotion
Open sixDoFRigidBodyMotion.C file with your favourite editor.
Near the bottom of the file:
After
<< "Angular velocity: " << omega()
add
" << nl"
to get std IO to jump to the next line
After the angular velocity line (but before the line that says
<< endl;
insert
 << "Orientation: " << Q()
Save and close the file and rerun Allwmake. The next time interDyMFoam is run, the IO will show the values of the Orientation tensor at each time step. The entire stream can be saved in a log file (e.g. log.interDyMFoam).
A bash script (e.g. extractData script found in the simple harmonic motion tutorial) can subsequently be used to extract time step and Orientation tensor value for further post-processing.
I think the orientation (Q) tensor is a rotational matrix generated by rotating in X, Y, Z sequence (still figuring this out at the moment......). If this is the case, then roll (i.e. rotation about Y axis) will be given by asin of the 3,1 element which should be the #7 of the 9 values of the Q tensor.
donQi, zhan, Yage and 3 others like this.
Old   October 13, 2022, 02:15
Akshay
Akshay80 is on a distinguished road
Dear Sir,
I also want to extract roll motion of floating body, as per your suggestions i extract orientation vector and plotted sin(3*1 element) entry w.r.t time. But my plot results are matching with experimental results. please suggest orientation vector only give rotational motion?.
Thanks,
Akshay
Akshay80 is offline   Reply With Quote
Old   October 13, 2022, 20:59
Tatsuya Shimizu
LongGe is on a distinguished road
Hi Akshay80
The coordinate system of a floating object is defined as follows.
coodinate: x -> surging y -> swaying z -> heaving
The transformation from the orientation tensor to Euler angles is as follows.
Orientation: (1 0 8.03123e-05 0 1 0 -8.03123e-05 0 1)->(xx xy xz yx yy yz zx zy zz)
trace = xx + yy + zz
s = 0.5/sqrt(trace+1)
w = 0.25/s
vx = (zy - yz)*s
vy = (xz - zx)*s
vz = (yx - xy)*s
//make quaternions
t11 = 2*(w*vx - vy*vz)
t12 = w^2 - vx^2 - vy^2 + vz^2
s2 = 2*(vx*vz + w*vy)
t31 = 2*(w*vz - vx*vy)
t32 = w^2 + vx^2 - vy^2 -vz^2
//Conversion between quaternions and Euler angles
angX = atan2(t11, t12) //rolling
angY = asin(s2) //pitching
angZ = atan2(t31, t32) //yawing
See: https://en.wikipedia.org/wiki/Conver...d_Euler_angles
Our Work: https://www.idaj.co.jp/product/ennovacfd/openfoam_gui/
Powered by Ennova : https://ennova-cfd.com/
Ennova's Channel Partners : http://www.wolfdynamics.com/
LongGe is offline   Reply With Quote
Old   October 14, 2022, 02:57
Akshay
Dear Sir,
Thanks for replying,
I plotted the graph as per your suggestions, I got the same graph as if i choose(1*3 element) i.e 3 rd element of orientation vector.
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
Inserting a floating object on a restart RileyJ FLOW-3D 0 October 24, 2011 16:05
Floating object in a fluid benjaminm CFX 7 November 14, 2009 05:46
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
