Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Compute fluid accellaration
Old   March 3, 2017, 10:06
Default Compute fluid accellaration
Kostas Margaris
kmargaris is on a distinguished road
Hi all,
How can I compute the fluid acceleration from the velocity field? Or in other words I want to calculate the material derivative of the velocity vector field.
kmargaris is offline   Reply With Quote
Old   March 3, 2017, 15:45
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
For example, there is fvc::DDt (https://cpp.openfoam.org/v4/a10924.h...6817560484a801).
alexeym is offline   Reply With Quote
Old   March 6, 2017, 09:37
Kostas Margaris
Hi Alexey,
Thanks for you quick reply. I take it from your answer that one has to write a custom application to compute the material derivative. I am not really familiar with OpenFOAM programming. Is there no way to calculate the material derivative with probe functions or in Paraview?
Old   March 6, 2017, 10:41
Alexey Matveichev
There is codedFunctionObject and in your case it could be as simple as
    acceleration
        libs ("libutilityFunctionObjects.so");
        type coded;
        // Name of on-the-fly generated functionObject
        name calculateDDt;
        codeWrite
            // Lookup U and phi
            const volVectorField& U = mesh().lookupObject<volVectorField>("U");
            const surfaceScalarField& phi = mesh().lookupObject<surfaceScalarField>("phi");
            // Write
            volVectorField t("DDt(U)", fvc::DDt(phi, U));
            t.write();
Maybe somebody else knows how to calculate it in ParaView (yet, guess, it is more complicated).
Old   March 6, 2017, 11:56
Kostas Margaris
Hi Alexey,
Thanks for the code. I added the code to my controlDict in the functions section.
With OF3.0+ I got a fatal error:
--> FOAM FATAL ERROR:
Unknown function type coded
Valid functions are :
4
patchProbes
probes
sets
surfaces
I tried OF1612+ and it works, but during solution only the material derivative is been written in the result directories. All other fields like U are not.
Any thoughts on these issues will be much appreciated.
Old   March 6, 2017, 12:13
Kostas Margaris
A further update. I managed to run the code with OF3+. Some changes were necessary.
acceleration
        functionObjectLibs ("libutilityFunctionObjects.so"); // This needed changing from libs to functionObjectLibs
        type coded;
	redirectType banana; //average; // needed to add redirectType, but the name doesn't seem to affect anything
        name calculateDDt;
	//outputControl runTime;
        code//Write // had to be changed from codeWrite to code
            // Lookup U and phi
            // Write
            t.write();
Now the behaviour during solution is the same as OF1612+. Only the material derivative is written as a result.
Old   March 6, 2017, 13:49
Alexey Matveichev
Is DDt(U) written on every time step? Add this:
writeControl    writeTime;
Here's configuration, tested on OpenFOAM 4.x:
    acceleration
        type coded;
        name            calculateDDt;
        codeWrite
            // Lookup U and phi
            // Write
            t.write();
Old   March 7, 2017, 05:41
Kostas Margaris
Hi Alexey,
I tried to compile OF4.1 but run into errors, so I couldn't test your code. However, I managed to get a solution in OF3+ and OF1612+.
For OF3+ this is my controlDict:
/*--------------------------------*- C++ -*---------------------------------*\
| \      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \    /   O peration     | Version:  3.0                                   |
|   \  /    A nd           | Web:      http://www.OpenFOAM.org               |
|    \/     M anipulation  |                                                 |
FoamFile
    version         3.0;
    format          ascii;
    class           dictionary;
    object          controlDict;
    location        "system";
libs            ( "libwaveAbsorption.so" "libwaveGeneration.so" );
write	0.5; // create a variable with the desired output interval
allowSystemOperations 1;
application     interFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         100.0;
deltaT          1e-05;
writeControl    runTime;
writeInterval   $write; // use the variable declared above here
purgeWrite      0;
writeFormat     ascii;
writePrecision  8;
writeCompression uncompressed;
timeFormat      general;
timePrecision   8;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           1;
maxAlphaCo      1;
maxDeltaT       0.05;
functions
    #include        "ProbeData"
    acceleration // The code was tested in OF3+ running serial and parallel case
        type coded;
	redirectType DDtU;
        name calculateDDt;
	writeInterval $write; // Re-use the write variable. This statement must be repeated here so that the output of all fields occurs at the same interval
	outputControl runTime; // This is also necessary in OF3+
        code//codeWrite does not work here in OF3+
            // Lookup U and phi
            // Write
            t.write();
For OF1612+ the controlDict is this:
FoamFile
    version         3.0;
    format          ascii;
    class           dictionary;
    object          controlDict;
    location        "system";
write	0.5;
startTime       0;
stopAt          endTime;
endTime         100.0;
deltaT          1e-05;
purgeWrite      0;
writeFormat     ascii;
writePrecision  8;
timeFormat      general;
timePrecision   8;
adjustTimeStep  yes;
maxCo           1;
maxAlphaCo      1;
maxDeltaT       0.05;
functions
    acceleration // The code was tested in OF1612+ running serial and parallel case
        type coded;
	redirectType DDtU;
        name calculateDDt;
	writeControl    runTime; //For OF1612+ writeControl is required not outputControl
        codeWrite //For OF1612 the correct statement is codeWrite not code
            // Lookup U and phi
            // Write
            t.write();
There are some small differences in the code for OF3+ and OF1612+. In both cases I found it necessary to use a variable "write" so I can write all fields at the same time interval. I tested the code in serial an parallel cases.
I am wondering if it is possible to write DDtU for a probe location?
Old   March 7, 2017, 05:59
Alexey Matveichev
You can:
1. Use probes function object. I think with correct order in functions dictionary it is possible to first write DDt(U) field and then probe it.
2. Use probes object directly in your coded function object. Though this way requires a little be more code, than just to write DDt(U).
Old   March 7, 2017, 15:26
Alexey Matveichev
I ended up with the following implementation: https://github.com/mrklein/foam-case...ontrolDict#L43. I have tested it on OF 4.x, so maybe it needs adaptation for OF+3.0 and OF+1602.
Old   March 9, 2017, 11:22
Kostas Margaris
Hi Alexey,
I managed to install OF4.1 and your code works very well. It also works in OF1612+ as is.
Now I tried to read the probe locations from a file in the system subfolder. I used the following code, but results in errors.
acceleration
        libs ("libutilityFunctionObjects.so" "db.so");
        type            coded;
        name            calculateDDt;
        writeControl    writeTime; //timeStep;//
        writeInterval   1;
        codeOptions
            -I$(LIB_SRC)/sampling/lnInclude
        codeLibs
            -lsampling
        codeInclude
            #include "probes.H"
	    #include "labelListIOList.H"
	    #include "fvMesh.H"
	    #include "fvCFD.H"
            #include "createTime.H"
	    #include "readTimeControls.H"
        codeData
            autoPtr<probes> probes_;
        codeRead
            List<word> fields;
            fields.append("DDt(U)");
            List<vector> locations;
            // Locations to probe, could be refactored into reading dictionary
            // instead of constructing it by hand
            locations.append(vector(1e-3, 1e-3, 5e-3));
	    locations.append(vector(  60,   -5.5,   -4.19  ));
	    locations.append(vector(  60,   -5.5,   -3.966  ));
	    locations.append(vector(  60,   -5.5,  -3.94  ));
	    locations.append(vector(  60,   -5.5, -3.69  ));
	    locations.append(vector(  60,   -5.5,   -3.44  ));
	    locations.append(vector(  60,   -5.5,   -3.19  ));
            IOdictionary probes
		IOobject
		    "probeLocations",
		    runTime.system(),
		    mesh,
		    IOobject::MUST_READ,
		    IOobject::NO_WRITE
	    dictionary conf;
            conf.add("fields", fields);
            conf.add("probeLocations", locations);
            // Initial acceleration field
            volVectorField t(
                IOobject("DDt(U)", time_.timeName(), mesh()),
                mesh(),
                dimensionedVector("0", dimVelocity/dimTime, Zero));
            t.write();
            probes_.reset(
                new probes(
                    "DDt(U)", time_, conf));
            // Probe and write for time = 0
            probes_->write();
        codeWrite
            // Lookup U and phi
            // Write
            t.write();
            // Write probes values
            probes_->write();
        codeEnd
            // To have probed value at the last time step
            t.write();
            probes_->write();
The dictionary file in the system subfolder is:
probeLocations
				(  60   -5.5   -4.19  )
				(  60   -5.5   -3.966  )
				(  60   -5.5   -3.94  )
				(  60   -5.5   -3.69  )
				(  60   -5.5   -3.44  )
				(  60   -5.5   -3.19  )
A second question; is it actually possible to write output to probes every time step, but write field data less frequently, say every 0.5 seconds?
Old   March 10, 2017, 16:02
Alexey Matveichev
I have updated example (https://github.com/mrklein/foam-case...e-acceleration) with the following additions:
1. Added examples for creation of probes from probesDict file and probes sub-dictionary of controlDict.
2. To be able to probe acceleration field every time step and to write it every write time, I have moved probing code to execute method. So now write frequency is controlled by writeControl and probe frequency with executeControl.
3. Got rid of field lookups on every write/execute method call.
Tested it on OpenFOAM 4.x, do not know if it works on other FOAMs.
Old   June 18, 2023, 01:58
Ahmadreza Ebadati
aeba402 is on a distinguished road
Originally Posted by alexeym View Post
I am looking for a function object so that I can calculate the acceleration field when running OpenFOAM as well. To me, it doesn't look like the code in the github link calculates the material derivative. Where is the dot product of the velocity and velocity gradient in the code? I also ran the code with some updates to suit OpenFOAM 1912 but it doesn't save anything in the postProcessing folder. It doesn't save anything in the time folders as well. Is someone able to help me with these please? This is the code I have used in my controlDict file.
    acceleration
        type            coded;
        name            calculateDDt;
        executeControl  timeStep;
        executeInterval 1;
        codeOptions
            -I$FOAM_SRC/sampling/lnInclude
        codeLibs
            -lsampling
        codeInclude
            #include "probes.H"
        codeData
            autoPtr<volVectorField> DDtU_;
            const volVectorField* UPtr_;
            const surfaceScalarField* phiPtr_;
        read
            // Constructing probes dictionary
            List<word> fields;
            dictionary conf;
            // Reading probes dictionary, let's assume it is
            // system/probesDict
            IOdictionary conf(
                IOobject("probesDict", time_.system(), mesh(),
                         IOobject::MUST_READ));
            // Getting probes dictionary from system/controlDict's
            // probes sub-dictionary.
            const dictionary& conf(time_.controlDict().subDict("probes"));
            UPtr_ = &(mesh().lookupObject<volVectorField>("U"));
            phiPtr_ = &(mesh().lookupObject<surfaceScalarField>("phi"));
            DDtU_.reset(
                new volVectorField(
                    mesh(),
                    dimensionedVector("0", dimVelocity/dimTime, Zero)));
            DDtU_->checkIn();
            DDtU_->write();
            probes_.reset(
                new probes(
                    "DDt(U)", mesh(), conf));
            probes_->write();
        execute
            DDtU_() = fvc::DDt(*phiPtr_, *UPtr_);
            probes_->write();
        write
            // Write
            DDtU_->write();
        end
            DDtU_->write();
            probes_->write();
Also I have added the probe locations as per below.
probes
    fields
        DDt(U)
    probeLocations
            ( 11 0.370 0 )
            ( 11 0.405 0 )
Thanks in advance. Cheers
aeba402 is offline   Reply With Quote
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 17:19
Compute Cluster with diskless compute nodes Pauli Hardware 0 October 6, 2015 16:48
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 13:57
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
