How to include "ScalarFieldField" class in foamToVTK |
October 25, 2023, 07:24 |
Anton
Rep Power: 4 |
Hey everyone,
I have ran a simulation using a custom solver which utilizes a kinematicCloud for the parcels. https://github.com/KAIST-LENSE/MP-PIC-PBE_CryFoam To post process the data in paraview I convert everything to VTK using foamToVTK. All scalarFields and vectorFields of the parcels are converted to VTK without issue, but there is one property of the parcels which is not converted - the property has the class "ScalarFieldField". It is essentially an array for each parcel. This is a snippet from when running foamToVTK, Code:
labels : active origId typeId origProcId scalars : d noNode kv minmodeTheta rho rhoc dTarget R_growthc nParticle age muc dr totalSource R_nucleationc supersatc tTurb vectors : UCorrect UTurb U Uc spherical tensors : symm tensors : tensors : This is what the FoamFile looks like Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class scalarFieldField; location "17.42/lagrangian/kinematicCloud"; object F; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 8400 ( 30 ( 1 1.67951e-11 3.44599e-23 4.60773e-35 4.51792e-47 3.46558e-59 2.16671e-71 1.13583e-83 5.09726e-96 1.98959e-108 6.83983e-121 2.09216e-133 5.74196e-146 1.424e-158 3.21043e-171 6.61408e-184 1.25083e-196 2.18009e-209 3.51424e-222 5.25569e-235 7.313e-248 9.49143e-261 1.1517e-273 1.30925e-286 1.39708e-299 1.40181e-312 0 0 0 0 ) ... ) Thanks in advance! /Anton |
October 29, 2023, 16:41 |
Mark Olesen
Rep Power: 40 |
No answer for you, but a question - what should an array of arrays represent in VTK? ie, which field type would this map to?
October 30, 2023, 05:51 |
#3 | |
Anton
Rep Power: 4 |
I am using a solver which is made to model crystallisation of lovastatin crystals through mixing a solution with an anti-solvent. This is done by using the Multiphase particle in cell solver (MP-PIC) which is then coupled with a population balance equation (PBE) in each lagrangian parcel. The distribution function of the crystals in the parcels is discretized into a set of bins which each contain a certain amount of crystals within a certain size interval. It is the number of crystals in each bin which is stored as an array, for all parcels in the domain which leads to the array of arrays. You can find the source to the original paper in the github-link in my original post. I believe I have managed to circumvent this issue by using my limited c++ skills to alter the solver such that each field associated with each bin is written as a separate file instead. Edit: Also I want it in VTK so I can save data for specific clips through paraview. There is probably an easier way to do this... Last edited by pierrevalis; October 30, 2023 at 06:02. Reason: Addition information. |
foamtovtk, kinematiccloud, mppicpbe, parcel, scalarfieldfield |
Colliding Coal Cloud in coalCollidingChemistryFoam | cmigueis | OpenFOAM Programming & Development | 28 | November 24, 2022 02:13 |
[waves2Foam] Problems compiling waves2foam solver | kenrichaiz | OpenFOAM Community Contributions | 15 | January 2, 2021 02:58 |
Mapping of pointFields with topology changes | mturcios777 | OpenFOAM Programming & Development | 16 | August 8, 2016 11:34 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 03:02 |
Writing a CFD code | davesmith_01 | Main CFD Forum | 13 | October 6, 2012 04:25 |
