Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Drag calculation for porous zone
Old   October 19, 2018, 03:53
Default Drag calculation for porous zone
Anders Dyhr Nørløv
MrAndersDk is on a distinguished road
Hello
I've tried to implement the following script, for a plate placed in a free flowing air. And calculated the drag coefficient on the square. This works really well. (The squareVolume reffers to the boundary around the square).
Now I would like to do the same, but where I have replaced the square with a porous region. Now I don't have the boundary to put into my script. I tried putting the volume of the porous region into the script but that does not work, and I get a value of zero.
I also tried creating a boundary around the porous region, however, then the boundary affects the simulation, and I could still not calculate the drag force.
Any idea how i could get the drag force on my porous region?
I've included a image of my simulation of the porous region. Clearly there should be a drag force on it.
forces
    type                forces;
    functionObjectLibs  ("libforces.so");
    outputControl       timeStep;
    outputInterval      1;
    patches             ( "squareVolume" );
    p               p;
    U               U;
    rho             rhoInf;
    log                 true;
    CofR                (0.25 0 0);
    rhoInf              1;
forceCoeffs
    type                forceCoeffs;
    functionObjectLibs  ( "libforces.so" );
    outputInterval      1;
    p               p;
    U              U;
    rho             rhoInf;
    log                 true;
    liftDir             (0 0 1);
    dragDir             (1 0 0);
    CofR                (0.25 0 0);
    pitchAxis           (0 1 0);
    magUInf             5.00;
    rhoInf              1;
    lRef                1;
    Aref                0.25;
MrAndersDk is offline   Reply With Quote
Old   October 26, 2018, 05:06
Anna Feichtner
AnnaF is on a distinguished road
Hi Anders,
I would be interested in something simlar... I have not tried it yet, but I was thinking about applying internal baffles (createBaffles with type "cyclic").
I guess I would have tried something like:
- createBaffles (type cyclic) out of faceSets/faceZones
- then I'd have 4 internal patches surrounding the porous are that are "empty"
- somehow link them together? to get one external surface...
- use this surface as input patch for the forces functionObject
However, that's just an idea... Please keep me updated about any progress
Best wishes,
Anna
AnnaF is offline   Reply With Quote
Old   February 8, 2019, 13:27
mechy is on a distinguished road
Originally Posted by MrAndersDk View Post
Hello
}[/CODE]
Hello
Dear MrAndersDk
I have the same problem
can you find a way for calculating this force ?
Best Regards
mechy is offline   Reply With Quote
Old   February 11, 2019, 04:10
Anders Dyhr Nørløv
Hello
Been some time since I looked at it, but I think I solved it.
I will post my case files later when I'm at my work compete, maybe first tomorrow.
Old   February 11, 2019, 05:17
Anders Dyhr Nørløv
Hello
Old   February 12, 2019, 11:53
Hello
Dear MrAndersDk
thanks for your kindness
Old   February 13, 2019, 06:56
Anders Dyhr Nørløv
here you go
baseCase.zip
Old   February 13, 2019, 10:05
Hello
Dear MrAndersDk
thanks again for your kindness
can you explain this case and its setting
its polyMesh folder is empty.
moreover, how you solved the aforementioned problem ?
Best Regards
Old   February 13, 2019, 11:21
Anders Dyhr Nørløv
The polymesh folder was too big for uploading. I'm away on a business trip, but when I get back I will have a look at it.
Old   February 14, 2019, 02:54
Anders Dyhr Nørløv
Hello
Now I'm back.
Look in the forceCoeffs file in the system folder. The solution is to include the porosity true line, and then the patch i put in my volume that has porosity.
The forceCoeffs file is then included in the controlDict.
Old   February 14, 2019, 16:15
Hello
Dear MrAndersDk
Best Regards
Old   February 28, 2019, 08:37
Anna Feichtner
Hey MrAndersDk
Thanks for sharing your case files.
I was just wondering, if the force and forceCoeffs calculation really worked as your attached .dat files in the postProcessing folder show only zeros?
And I have encountered problems with the forces functionObject utility for my current case, which is a 2D water wave interaction problem with a thin porous sheet (using interFoam/olaFlow). The forces utility gave me weird results, so I have used the pressureDifferencePatch utility instead, which gives reasonable results.
I would have thought it would give the same results, but it didn't and I still can't find the reason. Also the forces utility somehow cannot access my total(p) field, it only works for the p field for me...
Anna
Old   February 28, 2019, 08:41
Anna Feichtner
Oh sorry, I have opened the wrong files... So it was working!
And you are confident that the forces/forceCoeffs utility gives the right solution?
Best wishes
Anna
Old   February 28, 2019, 08:47
Anders Dyhr Nørløv
I have not verified the results. All I can say is that for my purpose the results makes sense. And others has made independent simulations in other programs and agree with my results.
But it is not well tested
Old   February 28, 2019, 08:55
Anna Feichtner
Alright, sounds reasonable. Thank you!
Anna
Old   January 8, 2024, 10:52
Kazakis Ioannis
Giannis_Kaz is on a distinguished road
Hello
Now I'm back.
Dear sir
How you connect porous media with patch?? patch also nedds boundary conditions!
Kind Regards
Yiannis
Giannis_Kaz is offline   Reply With Quote
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 06:04
Drag and lift calculation in Arbitrary Mesh Interface simulation anon_q OpenFOAM 7 April 22, 2018 13:24
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
