March 1, 2024, 06:18 |
Integrate a 3D scalar over one direction
annan
Rep Power: 9 |
Hi folks,
I have a 3D distribution of my temperature obtained after an openfoam simulation, and I would like to visualize a surface distribution of the average temperature over the z direction only. I have been trying to use programmable filters in paraview to do so, with no success. Can anybody help me achieve this please ? Many thanks! |
March 1, 2024, 10:08 |
Shravan
Rep Power: 9 |
Unfortunately, I cannot help you do this in Paraview. As far as I know it is quite hard to do this in Paraview. I have tried doing it in the past but couldn't manage to write a properly working programmable filter for this purpose. However I suggest you to use the columnAverage functionObject for this purpose (only available in ESI version). But you need to have a structured mesh https://www.openfoam.com/documentati...volume%20field. There are also some nice community contributions, for example see: https://github.com/syavash20/TurbLab...panwiseAverage Good luck! |
March 13, 2024, 06:29 |
annan
Rep Power: 9 |
Hello Severus,
Thank you so much for your valuable response. I have indeed tested columnAverage and it works perfectly since my mesh is structured. However, I wanted to use the same functionObject for temperature but the arithmetic average does not provide a satisfactory result. I think I need to integrate (U*T) in the z-direction, do you know any other functionObject that could help me compute this integral ? Many thanks! |
March 13, 2024, 13:19 |
Shravan
Rep Power: 9 |
Lets say you compute U*T, now can you use columnAverage functionObject? Will your results be satisfactory? Or are you only looking for something to integrate a variable along a direction? If your question is about how to compute U*T, you can look at codedFunctionObject, there are many posts out there regarding this. https://www.openfoam.com/documentati...8H_source.html Another option is define a new variable and simply multiply (U*T) inside your solver and recompile your solver. If your question on integrating in a specific direction using a functionObject, sorry I am not aware of anything. Thanks |
openfoam, paraview, post-processing |
Creating a transient .case file | scro1022 | EnSight | 0 | November 27, 2020 10:11 |
Calculating gradient for scalar considering flow direction | durg | Fluent UDF and Scheme Programming | 2 | April 11, 2019 10:12 |
Solving for an additional species CO in coalChemistryFoam | N. A. | OpenFOAM Programming & Development | 3 | February 18, 2019 05:58 |
How to apply an external forces on a moving body in interDyMFoam? | Larsa | OpenFOAM Running, Solving & CFD | 14 | July 31, 2018 10:41 |
dieselFoam problem!! trying to introduce a new heat transfer model | vivek070176 | OpenFOAM Programming & Development | 10 | December 23, 2014 23:48 |
