Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Integrate a 3D scalar over one direction
Old   March 1, 2024, 06:18
Default Integrate a 3D scalar over one direction
annan
annan is on a distinguished road
Hi folks,
I have a 3D distribution of my temperature obtained after an openfoam simulation, and I would like to visualize a surface distribution of the average temperature over the z direction only.
I have been trying to use programmable filters in paraview to do so, with no success. Can anybody help me achieve this please ?
Many thanks!
annan is offline   Reply With Quote
Old   March 1, 2024, 10:08
Shravan
Severus is on a distinguished road
Unfortunately, I cannot help you do this in Paraview. As far as I know it is quite hard to do this in Paraview. I have tried doing it in the past but couldn't manage to write a properly working programmable filter for this purpose.
However I suggest you to use the columnAverage functionObject for this purpose (only available in ESI version). But you need to have a structured mesh
https://www.openfoam.com/documentati...volume%20field.
There are also some nice community contributions, for example see: https://github.com/syavash20/TurbLab...panwiseAverage
Good luck!
Severus is offline   Reply With Quote
Old   March 13, 2024, 06:29
annan
Hello Severus,
Thank you so much for your valuable response.
I have indeed tested columnAverage and it works perfectly since my mesh is structured. However, I wanted to use the same functionObject for temperature but the arithmetic average does not provide a satisfactory result. I think I need to integrate (U*T) in the z-direction, do you know any other functionObject that could help me compute this integral ?
Many thanks!
Old   March 13, 2024, 13:19
Shravan
Lets say you compute U*T, now can you use columnAverage functionObject? Will your results be satisfactory? Or are you only looking for something to integrate a variable along a direction?
If your question is about how to compute U*T, you can look at codedFunctionObject, there are many posts out there regarding this.
https://www.openfoam.com/documentati...8H_source.html
Another option is define a new variable and simply multiply (U*T) inside your solver and recompile your solver.
If your question on integrating in a specific direction using a functionObject, sorry I am not aware of anything.
Thanks
openfoam, paraview, post-processing
Creating a transient .case file scro1022 EnSight 0 November 27, 2020 10:11
Calculating gradient for scalar considering flow direction durg Fluent UDF and Scheme Programming 2 April 11, 2019 10:12
Solving for an additional species CO in coalChemistryFoam N. A. OpenFOAM Programming & Development 3 February 18, 2019 05:58
How to apply an external forces on a moving body in interDyMFoam? Larsa OpenFOAM Running, Solving & CFD 14 July 31, 2018 10:41
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 23, 2014 23:48
