May 8, 2024, 23:15 |
OpenFoam to Fluent Data Transfer
Rep Power: 9 |
Hi
I've been struggling to understand the way OF exportrs the data file to a fleunt format. I've exported mesh file via foamMeshToFluent and data file via foamDataToFluent as instructed. I managed to import the results in the Fluent and create a case file. My geometry is simply a column against the flow. As shown in image-1, the pressure field on the column is visulised in Paraview as a caluclated by OpenFOAM. I then read the pressure in Fluent as shown is image-2, it however returns 0 pressure on the column surface that can't be correct!. I don't understand where I'm missing the procedure. I have tried another model with plate just to be sure but resulted the same. As shown in image-3, the total pressure of the same data file returns some values in Fluent but sttaic pressure is zero. I need to couple this column with ANSYS mechanical where the stress in the base of column can be calculated. As expected the mapped pressure is zero as apparently ANSYS mechanical reads static pressure as the field. I'd appreciate for any guidance if someone have come across this issue before. |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 20:06 |
Convert / transfer Fluent data to OpenFOAM 3.x | PeterPete | OpenFOAM Pre-Processing | 3 | September 14, 2016 10:00 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
