Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
New Utilities
Old   July 3, 2007, 20:33
Default Hi All, I am having a littl
Shaun Cooper
coops is on a distinguished road
Hi All,
I am having a little trouble with the results that I am getting from my model at the moment. I would like to try and chase down which terms in the equations may be causing the issues, therefore I would like to post-process each of the term in the initial equations.
1) is it possible to do this?
I have played with some post-processing with the velocity field which was easy but now I am interested in the energy equation terms.
For example I would like to look at the value of the following term:
fvm::div(phi, e)
This is the code that I am using at the moment:
\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\ / O peration |
\ / A nd | Copyright (C) 1991-2007 OpenCFD Ltd.
\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software; you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by the
Free Software Foundation; either version 2 of the License, or (at your
option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM; if not, write to the Free Software Foundation,
Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
Application
Ucomponents
Description
Writes the three scalar fields, Ux, Uy and Uz, for each component of the
velocity field U for each time
#include "fvCFD.H"
int main(int argc, char *argv[])
# include "addTimeOptions.H"
# include "setRootCase.H"
# include "createTime.H"
// Get times list
instantList Times = runTime.times();
// set startTime and endTime depending on -time and -latestTime options
# include "checkTimeOptions.H"
runTime.setTime(Times[startTime], startTime);
# include "createMesh.H"
# include "readThermodynamicProperties.H"
# include "readTransportProperties.H"
for (label i=startTime; i<endTime; i++)
runTime.setTime(Times[i], i);
Info<< "Time = " << runTime.timeName() << endl;
IOobject Theader
"T",
runTime.timeName(),
mesh,
IOobject::MUST_READ
IOobject Uheader
"U",
runTime.timeName(),
mesh,
IOobject::MUST_READ
IOobject rhoheader
"rho",
runTime.timeName(),
mesh,
IOobject::MUST_READ
// Check U exists
if (Theader.headerOk() && Uheader.headerOk() )
mesh.readUpdate();
Info<< " Reading T" << endl;
volScalarField T(Theader, mesh);
Info << " Reading U" << endl;
volVectorField U(Uheader, mesh);
Info << " Reading rho" << endl;
volScalarField rho(rhoheader, mesh);
Info << " Calculating phi" << endl;
surfaceScalarField phi
IOobject
"phi",
runTime.timeName(),
mesh,
IOobject::NO_READ
linearInterpolate(rho*U) & mesh.Sf()
Info << " Calculating e" << endl;
volScalarField e
IOobject
"e",
runTime.timeName(),
mesh,
IOobject::NO_READ
Cv*T
Info << " Calculating div(phi, e)" << endl;
volScalarField div_phi_e
IOobject
"div_phi_e",
runTime.timeName(),
mesh,
IOobject::NO_READ
fvm::div(phi, e)
else
Info<< " No T" << endl;
Info<< endl;
return(0);
I am able to read in the various field and calcuate some of them but when I want to calculate div_phi_e I get an error.
I think it is because it is not a volScalarField becuase I am trying to take the divergence of a field that is not a volVectorField, but I don't know what else it should be, or if it is even possible to compute!!!
Many Thanks,
Shaun
coops is offline   Reply With Quote
Old   July 4, 2007, 04:21
Default Have a look at chapter 2.4 of
Assistant Moderator
Bernhard Gschaider
Have a look at chapter 2.4 of the Programmer's Guide: Equation discretizations. What you're looking for is fvc::div. The explanation is found there.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
How to make utilities Parallel aware philippose OpenFOAM 5 October 20, 2011 09:41
New proSTAR%2360OpenFOAM conversion utilities olesen OpenFOAM 18 June 22, 2010 03:07
Proposal for an extension for the timeoptions of Utilities gschaider OpenFOAM Bugs 5 August 26, 2008 19:13
Utilities to download for research/programmers For those who favor open-source Main CFD Forum 0 September 21, 2006 16:03
Running utilities for a given time step melanie OpenFOAM Running, Solving & CFD 2 March 10, 2006 07:28
