April 15, 2009, 12:08 |
Monitor viscosity - RhoSimpleFoam
Alain Bouvier
Rep Power: 17 |
I'm using the rhoSimpleFoam solver and i'm tryin to print both viscosity mu and mut in every cell. My problem : unlike p, this viscosities aren't created -in creatField.H- with a volScalarField declaration but came from compressible::RASModel. So they don't appear in the volfieldstatus panel in paraview. Does somebody know how to access this datas, in paraView or with any other means ? Thx for your help Alain |
April 17, 2009, 02:47 |
Default Monitor viscosity - RhoSimpleFoam
Mark Olesen
Rep Power: 40 |
Attached are two examples of post-processing utilities for calculating the laminar and turbulent viscosities. If you are not fussy about getting the Cmu value from the dictionary (or if you have different dictionaries than I do), you can comment out that bit (eg, with #if 0 .. #endif).
Creating a non-compressible version shouldn't be too hard either. |
April 17, 2009, 08:01 |
Alain Bouvier
Rep Power: 17 |
Thx for your answer.
I have solved this problem by switching mu in basicThermo.C (and mut in kEpsilon.C) from NO_WRITE to AUTO_WRITE, but your solution is far less intrusive. I'm knew to OpenFoam and your exemples are a good way for me to go further in the code understanding ; - ) |
April 17, 2009, 08:18 |
#4 | |
Mark Olesen
Rep Power: 40 |
You could try this in the main time-loop (haven't checked if it actually works): Code:
if (runTime.write()) { thermo->mu().write(); turbulence->mut().write(); } |
April 17, 2009, 08:53 |
Alain Bouvier
Rep Power: 17 |
Thx,
it works but only for mu. I don't know why but mut "has no member named ‘write’". I've achieved to post-process mu and mut so I'm happy ; - ), even if a clean solution is always welcome |
April 24, 2009, 18:37 |
#6 | |
Nugroho Adi
Rep Power: 17 |
Thanks for your post processing utilities im sorry, stupid question, could you please teach, clear step by step how to work with your post-processing utilities for calculating the laminar and turbulent viscosities? im facing a similar case. please give me help |
monitor print viscosity |
TRANSONIC FLOW in RHOSIMPLEFOAM | dinonettis | OpenFOAM Running, Solving & CFD | 10 | September 13, 2018 10:22 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
RhoSimpleFoam | jphandrigan | OpenFOAM Running, Solving & CFD | 18 | March 29, 2009 11:05 |
RhoSimpleFoam FoamX | spv24 | OpenFOAM Running, Solving & CFD | 1 | July 21, 2008 10:29 |
Stability startup problems with rhoSimpleFoam | olesen | OpenFOAM Running, Solving & CFD | 1 | July 18, 2006 08:09 |
