Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Velocity profiles near walls?
Old   April 23, 2009, 04:01
Question Velocity profiles near walls?
Hectux is on a distinguished road
I ran in the last days some simulations in pipe geometries.
In ParaView I to wanted to plot the velovity profiles (y: Velovity, x: Radius).
In the center of the tube everything worked great. But near the walls I had a region where the velocity was everywhere the same.
I thought I had a problem with my simulation. So I took the tutorial cavity for icoFoam, altered it a bit to see the profile well and ran it.
The same profile. In the centre was everything good and nearer to the walls I had a jump to the wall velocity. Actually I expected a smooth raise of the velocity to the wall.
In my simulation the geometry is much smaller and the region near the wall therefore much bigger than here. Thats not what I expected or what it should be.
I attached the two pictures with the profiles and marked the regions.
Thanks for help.
Hectux is offline   Reply With Quote
Old   April 23, 2009, 09:03
Problem solved....almost.
When I use Sample from OpenFoam and import the Data to Excel I get a good smooth profile. Do not know why ParaView creates such profiles.
Any sugestions why?
Old   April 23, 2009, 10:09
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Hi Hectux,
Try to increase the number of points in the x-y plot, and see if it helps.
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   April 23, 2009, 14:37
Yes. Thats probably the problem. But I cannot find the funkction to increase the number of points.
With SampleDict it was no problem to set 10 oder 500 points.
Old   April 23, 2009, 18:27
Nugroho Adi
mahaputra is on a distinguished road
Dear Hectux
could you please teach step by step, how you work with SampleDict to plot your xy velocity profile?
im facing a similar case.
please give me help
mahaputra is offline   Reply With Quote
Old   April 24, 2009, 04:46
Ok.
First there is an example file of SampleDict in $FOAM_UTILITIES/postProcessing/sampling/sample
There is a complete SampleDict file with every functions. You will find a better description in the UsersGuide of OpenFOAM.
The SampleDict is saved in the system folder. Often you have to create a file on your own:
My SampleDict is quite simple but it works well for me:
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object sampleDict;
interpolationScheme cellPoint;
setFormat raw;
sets
profile
type uniform;
axis y;
start (0 -5e-4 2e-3);
end (0 5e-4 2e-3);
nPoints 500;
surfaces
fields
U
What it does: Creates a line with evenly distributed 500 points. Start point (0 -5e-4 2e-3) end points (0 5e-4 2e-3).
Thats a cut through the center of my pipe.
With fields: U
I get a file which I can import to e.g. Excel or Spreadsheet.
So I have 4 colums. First: The coordinates of my points, second: Ux component of the velocity vector in that point, third: Uy, fourth Uz.
I had to change the punctuation from "." to "," in Excel but that should be no problem, I think ;-)
Old   April 24, 2009, 08:35
santos's Avatar
Jose Luis Santos
I guess you missed it.. If you look in the Properties tab of ProbeLine filter, at the bottom you have the Resolution option with a default of 100. Try to change this value to see if it helps.
Regards,
Jose Santos
Old   April 24, 2009, 18:33
Nugroho Adi
Dear Hectux
thanks for your tutorial, thousand thanks.
regarding plotting, maybe you can use xmgrace tool
sudo apt-get install xmgrace
this software really easy to use compare excell (at least for me)
Old   May 20, 2009, 09:37
Default help with xmgrace
lth
lth's Avatar
lth
lth is on a distinguished road
Hello Hectux,
I read your post and have not been able to get xmgrace to plot anything. I installed and when I run a sampledict and have sets files filled, I run xmgrace and the postprocessing window opens, however, i am not able to bring up any plots? Can you say what is needed to get the data showing?
Thanks for any advice, Lori Holmes
lth is offline   Reply With Quote
Old   May 21, 2009, 09:42
Sorry, I am not using xmgrace. I am still using Excel.
I suggest you write mahaputra an private message.
Old   May 21, 2009, 09:49
Nugroho Adi
Hei lth
follow this :
Use: Data/Import/ASCII. Choose the logs directory and remove '.dat' from the filter. Then you can plot whatever you like in the logs directory.
hope this help
cheers
Old   May 21, 2009, 09:51
Nugroho Adi
Originally Posted by lth View Post
Hello Hectux,
see this one:
http://www.cfd-online.com/Forums/ope...-plotting.html
Velocity Profiles Sal FLUENT 3 August 2, 2007 09:06
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Velocity profiles Rex FLUENT 4 July 23, 2002 19:35
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Velocity profiles merac FLUENT 2 May 23, 2001 04:54
